Not getting full re...
Not getting full rear travel. What should I try? Nukeproof Reactor content
[#13062784]
Got back from the Pyrenees last month, and I spent all week fettling with my rear air pressure, but never got full travel. Nukeproof Reactor 130mm. Fox Float DPX2, Factory Series.
First thing I checked was letting all the air out. Yes, the wheel hits the frame!
I tried between 220 and 250 psi. The only way to get nearly full travel was to have 40%+ sag.
The riding was pretty full on (Ainsa Zona Zero) and I wasn't hanging about.
I had the shock serviced with JTech before I went. I guess I need to play with volume spacers....?
Posted : 01/12/2023 2:29 pm
Do you know how many Vol Spacers it has ?
What's the recommended sag for the frame ? Some are more or less than other frames.
Why not run it at 40% sag ? Is it sitting too low in the travel ?
Posted : 01/12/2023 2:33 pm
 5lab
Less volume spacers would be the answer, or just ride it harder.
Do you know you're not getting full travel? Wheel hitting frame is worrying
Posted : 01/12/2023 2:41 pm
What stroke shock have you got fitted? Reactor takes a 210x50mm shock. This is the same shock as 210x55mm shock just with a travel spacer fitted, so you wouldn't expect the o ring to reach the end of the shock. Caveat to this is I don't know what markings your shock will have on it.
Pretty sure the rear wheel shouldn't be contacting the frame with all the air out - if it is then I'd be grateful that you're not getting full travel!
OK, it's not hitting the frame but with the air out, but the shock gets full travel.
Guess I need to open it up this evening and check the spacers...
Posted : 01/12/2023 2:48 pm
DPX2 in my experience feel/ride quite soft in the initial stroke anyway.
Posted : 01/12/2023 2:49 pm
The thing to consider is...
Did it ride ok? Did you feel like you were short of travel, or just going by markings?
If it's the latter, I wouldn't worry about it
Posted : 01/12/2023 2:52 pm
