not getting enough ...
[Closed] not getting enough l travel help !!!
[#3231005]
I have a pair of fox float 32 forks which was 140mm but I reduced the travel with a spacer to 120mm . what I find is i;m getting nowhere near 120 mm more like 100mm . I know you dont get full travel but should I get more than 100mm out of a 120 fork ??? cheers
Rich
Posted : 10/10/2011 7:41 pm
 jonk
Let all the air out and check the travel. If you are getting full travel then there is too much air in the chamber in order to get full travel. My 130 floats never get more than 120 because of my weight and the amount of air in there.
Posted : 10/10/2011 7:52 pm
ok cheers
Posted : 10/10/2011 7:59 pm
I dunno how Fox forks work but if they have a negative air chamber then I think this needs to be either equal or less than the positive to achieve full travel.
Posted : 10/10/2011 8:01 pm
