Nordest bikes - any...
[Closed] Nordest bikes - anybody got one?
 Rik
[#9825617]
Look really nice esp. the Ti one! Under 2kg as well for the largest size bit more expensive than the Kingdom X2 but lighter.
But 160mm on a hardtail that's a big change in geometry if you bottom out the forks?
Posted : 08/02/2018 5:45 pm
 Rik
Sure I've seen a few on here
Posted : 08/02/2018 10:44 pm
Mrs Stu has a Bardino.
Well made and though out frame.
The guys are easy to deal with too and even sent her a free shirt.
I think the geo is slack enough for a 160 fork to not be a problem.
[url= https://farm5.staticflickr.com/4599/24399235147_04ae81e773_c.jp g" target="_blank">https://farm5.staticflickr.com/4599/24399235147_04ae81e773_c.jp g"/> [/img][/url] by [url= https://www.flickr.com/photos/stu-b/ ]multispeedstu[/url], on Flickr
Posted : 08/02/2018 11:21 pm
Nice ass, Mrs Stu!
Posted : 08/02/2018 11:22 pm
That's Eli the donkey.
He ain't no ass.😄
Posted : 08/02/2018 11:28 pm
Posted : 08/02/2018 11:39 pm
Like the look of their Lacrau Pinion bike. If my Sick frame doesn't materialise I'll be looking at that some more
Posted : 08/02/2018 11:45 pm
 Rik
Lovely looking bike there Stu and thanks for the input.
Is that set up with 160mm 29er forks and 29er wheels?
If so - is there any chance you might be able to measure the static bottom bracket height in that set up?
They only give sagged bb drop on the geometry chart so it would be good to get another measurement.
Thanks
Posted : 09/02/2018 8:53 am
Yep 160 fork and 29er wheels.
Got to do some work on it later so i'll measure the bb height for you then.
Posted : 09/02/2018 9:14 am
 Rik
Cheers Stu 👍
Posted : 09/02/2018 9:49 am
Measured it earlier and cant remember for sure 😳  but think it was 330mm.
I'll check again tomorrow for you.
Posted : 09/02/2018 7:45 pm
 Rik
Cheers - much appreciated but an accurate measurement would be ace 😂😂
Posted : 09/02/2018 9:45 pm
That’s a smart looking bike. If you don’t mind me asking what sort of price range are they, frame only or full bike? Sweet donkeys too!
Posted : 09/02/2018 10:58 pm
https://nordestcycles.com/en/product/bardino-frame
The donkeys are very cool.
They always come over to the fence when they see us coming across the field towards them.😎
Posted : 09/02/2018 11:11 pm
 Rik
They certainly look the part - interesting that the largest size looks to keep the bear straight through top tube/seat stays line and just adds in a larger extended seat tube support
Posted : 10/02/2018 2:27 pm
 Rik
Bump to remind Stu to get the measuring stick out again 😃
Posted : 11/02/2018 12:21 pm
Rik
I'll try and remember but I'm currently in the pub so it might be tomorrow.😉
Posted : 11/02/2018 2:21 pm
 Rik
Pub - sounds good, cheers man
Posted : 11/02/2018 4:10 pm
OK.
It's somewhere between 325 and 330 mm to the center of the BB
Can't get any more accurate than that as I can't see if I'm holding the bike up dead straigh when I'm measuring it.
Posted : 12/02/2018 5:02 pm
 Rik
Spot on Stu - big thanks.
Now for a play in BikeCAD
Posted : 12/02/2018 5:18 pm
 Rik
One more easy question Stu - from your Flickr feed it looks like your running an old XT Non-Boost chainset on there with a 30t narrow wide chainring in the middle position? If thats all correct presumably it all plays nicely and clears the chainstay plate as its a boost 148mm back end.
Posted : 12/02/2018 6:48 pm
Yep old XT crank with inboard mounted 30T
Fits fine, around 4-5mm clearance at the chainring/plate area.
Posted : 12/02/2018 8:05 pm
