Same Q as before - when your joplin is in the down position, you pull up the lever, does the saddle pop up like the remote version or do you have to pull the seat up by hand??
It needs some encouragement. The pressure on the lever required to activate it is sufficient that it will be enough to lift the saddle too.
Comprendez?
mark - mine has NO spring up what so ever, riding buddy with remote - his pops very quickly!
Why not try one? Now don't go askin' a question after you bought it now RR 😉
essentially grab lever and pull saddle up - like it has no air pressure in the cylinder what so ever
foxy - fair point. I am unsure if it popped up when new (think it did) but its niggling me. As stated i tried my mates with remote today and that had a definite snap back up with no help!!
😉 - Just pullin' yeh leg
they don't 'pop up'. they are damped.
got a vid?
his definitely does. Mine does return to the up position unless i drag it up. Do they have air in a chamber? if so - is it possible its leaked??
hmm shouldnt need dragged.
is it spongy at the top position?
no - stops where ever i want it to if i pull it into position
well it sounds like it works.
:shakes head:
