Non UST tyres runni...
[Closed] Non UST tyres running tubeless?
[#5582269]
As the title says, whats stopping me running my non UST Ardent and Crossmark tubeless? mAny one tried?
Posted : 08/10/2013 10:18 am
Nothing. I've done non-ust Highrollers and Continental Barons… probably some others too.
UST tyres have a slightly different bead higher grade rubber so it's easier to seal. Think of them as 1.5ply.
Posted : 08/10/2013 10:21 am
It can work, but they can be fragile, loose etc.
Posted : 08/10/2013 10:32 am
Run both on Stan's rims with no problems. They are weaker, as Al said, though; I'd go with Exo casing or just LUST at least for the rear.
Posted : 08/10/2013 10:40 am
I run non-tubeless Bonty XR4s tubeless with Eclipse rim tape and Stans sealant and once installed, have had no problems.
Posted : 08/10/2013 10:57 am
I've ran lots of non-tubeless maxxis tyres including standard and exo ardents tubeless with no problems.
Posted : 08/10/2013 11:04 am
All tyres are possible, but as you slide from UST to TLReady to Folding bead to wire bead, your chances of a faff/leaks/burps/blow off increase.
Posted : 08/10/2013 11:19 am
Maxxises tend to work well, quite a lot of rubber in them, and quality beads.
It's more about guarantees- most standard tyres do work well but without going UST or (better, IMO) tubeless ready you don't know until you try. Even if a previous tyre worked well, no guarantee the next will as the QC isn't designed for tubeless.
I think I'm about 50/50 with TLR vs standard just now, no USTs.
Posted : 08/10/2013 12:34 pm
This rule also applies to buying fizzy pop.
And your choice of curry house.
Posted : 08/10/2013 12:59 pm
I've done it on the front (ghetto) but not on the rear. Sidewalls are too delicate for rears.
Posted : 08/10/2013 1:12 pm
 devs
I've done it for years on Flow rims with mostly Maxxis tyres. NEVER ripped a sidewall despite being very heavy and pretty clumsy and it being on a hardtail. Just don't run them silly soft.
Posted : 08/10/2013 1:47 pm
I'm running some onza ibex edc casing on my ex823 without any problem. They went up first time fine.
Posted : 08/10/2013 3:59 pm
look on stans website they list some as a no no, think its in support section
Posted : 08/10/2013 4:18 pm
I've had good results with various Maxxis Exo tires - usually it's just a bit more of a pain to get them inflated than with UST (needed a compressor with my Ardents)
High Roller weeped sealant from the bead (where there were molding lugs), but sealed up eventually.
TRL Bonty's have been great too (Big Earl and XR4s) - surprisingly tough for their (relatively) light weight.
Posted : 08/10/2013 4:23 pm
Nice one! Thanks everyone for your experiences, I'll give it a shot and see what happens.
Posted : 08/10/2013 4:25 pm
