Non standard pads.....
[Closed] Non standard pads.... Good or a false economy?
[#7989610]
I need to stock up on several sets of Hope X2 pads, and at £12 ish quid a pair it's going to cost me the best part of £70!
Can anyone recommend any cheaper alternatives such as Uberbike or superstar etc or are the cheaper ones made from squealy chocolate?
Floss
Posted : 08/08/2016 9:17 pm
Superstar Components might have em.. I got 5 or 6 pairs for £25ish
Posted : 08/08/2016 9:21 pm
Uberbike or Superstar
 jimw
I have spent some time and a bit of cash over the years trying out a number of different makes.
And I am now only using Hope.
The disco brakes ones seem to be pretty good from my experience.
Posted : 08/08/2016 9:33 pm
Either Superstar or Uberbike sintered for me. Uberbike race matrix if I'm feeling fancy, but Superstar's kevlar are cack.
They both have fairly regular discount codes too.
Posted : 08/08/2016 10:31 pm
as I get thousands of miles out of hope sintered I see no need for anything else.
Posted : 08/08/2016 10:46 pm
I used to get through a lot of pads, tried superstar and felt they were worth it due to the speed I got through them. Then after a bunch that were too thick I went back to genuine. My hope and shimano last long enough for me not to worry about the cost.
Posted : 08/08/2016 11:27 pm
 Del
discobrakes for me. their site is gash though. you don't need to create an account with them to buy.
Posted : 09/08/2016 12:01 am
Hope's pads are very good tbh.
Personally I like superstar kevlar but performance varies from brake to brake, imo they're superb in formula but weren't so excellent in my old XTs. Discobrakes were alright but I had some pad material fails
Uberbike's race matrix are one of the few bike parts I threw in the bin rather than wear out- they were alright for bimbling at home but day 1 in the alps and they shat the bed completely, I think they just couldn't cope with harder use- wildly inconsistent, they'd grab on one corner and have no stop on the next, horrendous.
Posted : 09/08/2016 12:36 am
Shimano are cheap and far better than aftermarket jobs. Well, they were cheap...
Posted : 09/08/2016 5:06 am
I've always been very happy with superstar but like above, on a recent Alps trip I threw away a few-runs-old set of sintered in my XTs as I just couldn't stand the hideous squealing at the slightest touch.
Generally they've been spot on though. Uberbike worked well for me too.
Just recently been tempted by on-one at two notes each. Hmmmmm....Will I die I Wonder?
Posted : 09/08/2016 6:05 am
Wiggle do a limited selection for £2 I'll be getting some in my next order to get free postage, not had a problem with any of the lifeline branded stuff so far.
Posted : 09/08/2016 6:42 am
Anything other than OE or Goodridge I find wear down at a rate that negates any saving.
And most have either been noisy, or generally just crap.
Posted : 09/08/2016 6:51 am
Tried Superstar but was never that impressed, I found in particular they were not the exact depth of OE pads. Always returned to Hope, Formula and Shimano in the end.
Posted : 09/08/2016 7:01 am
first stop for me is always disco. especially good value if you're buying multi packs.
Posted : 09/08/2016 8:33 am
Depends. Something like ebc or goodridge might even be better than OE (depending by what measure, performance, durability, feel). Something from uberbike or discobrakes might be so crap is almost funny. Or it could be as good or better than OE. Who knows.
Depends how much risk you want to take.
I had one (large) batch where i had to replace pads on an almost race by race basis. If i forgot and it rained I'd need new discs after they got gouged by the backing material. In hindsight i should have binned them.
The EBCs or OE Shimano I've got on everything at the moment haven't been touched in several months.
Posted : 09/08/2016 8:54 am
I don't understand this. The thickness will vary as they wear down, so why is it critical. New ones will be thicker so the pistons will need pushing back in (though admittedly there's a point at which they're just too thick to go in). What am I missing?
Posted : 09/08/2016 9:18 am
There's a limit to just how thick the caliper can take. If they are too thick out of the packet, you won't be able to fit them without removing some pad material.
Posted : 09/08/2016 9:26 am
you're not missing anything
/edit beaten by one second! 👿
Used to be pro-Superstar, but I've certainly had ones that are in fact to thick to go in. The extra thickness was on the backing, or the shape of the backing, and not extra braking material.
Then I wrote a pair of sintered ones off in about 300km compared to way more than that for Formula organic (which had more stopping power too). Road side pad change with pads fatter than will fit is fun 😉 They weren't the ones where the entire material fell off, but bits did fall off due to going so thin.
Don't know about false economy, but on a 4 grand bike, and the price of potential dental work, I choose quality and reliability over saving the price of a pint or so.
Formula do run very close to pads as standard, so there's very little tolerance to play with. So after that foray with Superstar I always used genuine Formula after that. Now using Shimano, but only with the real thing. Can't speak for other brands and their replacements.
Posted : 09/08/2016 9:28 am
Yup.
Posted : 09/08/2016 9:39 am
Clue: I like my wheels to actually rotate.
Posted : 09/08/2016 12:22 pm
Clarks organics - 7 quid a pop, available at your LBS for that price too, cracking pads.
Posted : 09/08/2016 12:27 pm
 Del
also bear in mind that sometimes the conditions can just be 'wrong' for the pads you're using. i've had OEM pads last no longer than 2 rides, and cheap aftermarket do the same, but similarly cheap aftermarket last 9 months.
take the anecdotal evidence as just that. 😉
Posted : 09/08/2016 1:28 pm
I pretty much only buy from Superstar or Disco nowerdays (probably had 30+ sets) - performance & life has been on a par with OEM ones - I am yet to have any issues
Posted : 09/08/2016 1:34 pm
Superstar have always been very good for me, I haven't noticed any real difference in depth, or braking power or even wear. I've recently bought some of their finned ones, I don't really know why, for me that only really make sense in the Alps, over here I don't get to ride anything long and steep enough to get that sort of heat into them.
Posted : 09/08/2016 1:40 pm
You realise the pistons move in and out right?
Posted : 09/08/2016 1:42 pm
Yeah. But you can't make the slot in the caliper body wider.
Posted : 09/08/2016 1:44 pm
I find Shimano OEM pads brilliant - had a set that literally lasted years on the DH bike - alps trips, finale, antur, revolution, all sorts and didn't need replacing. Think I still have the fronts
Posted : 09/08/2016 1:52 pm
That I did not know.
Posted : 09/08/2016 6:26 pm
Actually I take back what I said about DiscoBrakes. I made a bulk order late last year, but for one reason or another, only just got round to fitting them. The tolerances must be out as none of the pads fit the callipers, pad material + backing plate is too thick. Emailed them, and effectively they said tough luck. Not impressed. Wont be using them again.
Posted : 17/08/2016 8:52 am
Have never had much luck with any of the cheap brake pads. They either don't fit properly or they make a noise or generally **** up otherwise perfectly acceptable/sensational/expensive brakes.
Posted : 17/08/2016 9:00 am
 tomd
+1 for but with Shimano. I've had too many issues using "cheap" alternatives. The manufacturer's originals tend to last really well too.
Posted : 17/08/2016 9:11 am
