Recommendations for non-slip paste for steel frame and Reverb post please. Will the equivalent from an auto shop do?
I would use copper grease. Buy it from a auto shop as it's vastly cheaper. The point of the grease is to stop the two different metals seizing together.
If it were a carbon frame then you would want grip paste like the Finish Line Fiber Grip stuff.
[i]The point of the grease is to stop the two different metals seizing together.[/i]
but the paste also reduces the clamping force needed to hold the post in the frame so I use paste regardless of frame and seatpost materials.
I've been using copper grease, no issues.
my KS posts all say to use paste (and I think there was a sachet in the box?) to avoid bending the outer tube with the seat clamp and stopping it working.
Cheers guys. A tub of non-slip paste in the LBS is £30 ❗ which for something I'm only going to use very occasionally is somewhat pricy.
I used copa slip on the KS Lev and it's all good - get it for a fiver on flea bay.
£7.99 for 50g, which is likely a lifetimes supply.
http://www.chainreactioncycles.com/finish-line-fiber-grip-assembly-gel/rp-prod30012
+1 for the small tube of Finish Line Fiber Grip
Use it on all my stems and seatposts out of habit now, carbon or otherwise it's just a little bit of extra peace of mind IMO.
For £7.99 it's a no brainer.
I'd seen that - by the time I've used all that I'll be needing some teflon paste on my own joints! 😀
another +1 for Finish Line fiber gel. I had a slippy creaky Thomson in my RL853 and tried 3 or 4 different carbon pastes until trying the Finish Line, which cured it. I now have it on all bikes, which include steel, alloy and carbon frames.
