My friend has a 2012 Nomad with the 1.5" headtube. He used to have some RS forks on it with where a standard steerer tube but has just got some FOX 36 and they have a tapered steerer.
The headset he has now is a Syntace one and is semi-integrated i believe (Pic to confirm). Am I correct in thinking that he can keep the top of the headset what is on now and fit this lower:
http://www.westbrookcycles.co.uk/components-hardware-c8/headsets-c81/hope-pick-and-mix-headsets-p197423?utm_source=froogle&utm_medium=ppc&utm_term=hope-pick-and-mix-headsets-type-tapered-1-5-quot-to-1-1-8-quot-reducer-crown-type-tapered-1-5-to-1-1-8-reducer-crown&utm_campaign=froogle#239588
(The bottom one in the middle)
Headset now (Semi-Integrated?):
[IMG]
[/IMG]
Thanks
Anyone help with this?
You need an external bottom cup headset with a tapered fork this is the standard EC49/40, have a look at this guide http://chrisking.com/headsets/hds_inset click on the 49mm headtube guide.
It doesn't look like hope do one.
Still no clearer to me lol.
Losing the will to live trying to find a headset for this.
Thanks for the help though.
i think you need the bottom right one in the link you provided. but to make sure if you bump this thread in the morning im sure someone in the know will be in work with not much to do
Cheers.
Do you think this would work: http://www.chainreactioncycles.com/Models.aspx?ModelID=60703
This is what you need http://www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=85847 or this http://www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=83921
The one you have listed above sounds like it will do the job.
The head tube on a Nomad is designed with a diameter of 49mm so you can't fit a internal lower cup if running a tapered fork it needs to be external hence the EC in the lower cup spec and the 49 for the head tube diameter and 40 for the crown race on a tapered fork.
Thanks for that.
Just to confirm will this fit http://www.chainreactioncycles.com/Models.aspx?ModelID=60703
BUMP 🙂
Yea that sounds like it will fit the head tube the problem is the one shown in orange in the photo looks like it comes with a crown race for a 1 1/8 fork not a tapered, where the black one looks like the correct crown race.
Might be an idea to check with CRC before ordering as it doesn't state in the description either way.
Good spot. I will give them a call and tell me mate to order that one.
Thanks for the help, Finally sorted!!
