Hiya chaps,
I've got a brand new Fox DPX, and it's pretty noisy. Doesn't sound cavitated or anything, it just sounds like the dampers are a bit noisy. With rebound fully open you can hear the air wooshing through the shock, or maybe the oil through the rebound damper.
With the damping more closed, it sounds quieter.
You can also hear the piston a bit squeaky, which is what I've had on brand new DPS shocks too.
Is the damper normally a bit noisy? I can't remember if the X2 was the same, as it was dual piston too...
Ricks !
Posted : 18/03/2018 10:43 pm
