Nobby nic evo ghett...
[Closed] Nobby nic evo ghetto tubeless?
[#2551017]
Are these any good tubeless or are they too porous? If they're rubbish tubeless, what could people reccommend? I've heard maxxis are good ghetto tubeless.
Posted : 10/03/2011 7:54 pm
Ran a NN Evo on the front with Stans Fluid for most of last year. Bit of a bugger to seat initially but perfect after than.
Been running Maxxis Advantage (non UST) tubeless since November and they have worked perfectly too.
Posted : 10/03/2011 8:24 pm
I have two of the NNs running tubeless on my Blur. One is perfect, the other needs topping up with air regularly 😕
Edit: I'm gonna swap them out for Advantages anyway.
Posted : 10/03/2011 8:25 pm
How well do advatages roll?
Posted : 10/03/2011 9:00 pm
In a circular motion
Posted : 10/03/2011 9:06 pm
I got a puncture that wouldn't seal on the first ride but otherwise fine- they were very tight on the beads, hard to get one side sealed.
Posted : 10/03/2011 9:20 pm
The 2011 NN's are tubeless ready, the 2010 pair I have have sidewalls more porous than a sponge, trying to ghetto them turned my garage in to an Ibiza foam party 😯
Posted : 10/03/2011 10:33 pm
Just fitted a pair of older Nobby Nic's snakeskin, one on a Mavic 717 rim with stans rim strip and one on Stans ZTR crest rim with stans yellow tape, both went on and inflated really easy. Used a track pump, with no problems, probably the easist I have done.
Posted : 10/03/2011 10:41 pm
 pb2
I'm struggling with a 2010 29" NN Evo triple compound non UST tyre, I'm using a 26" tube with the rim tape removed and the wheel is 29" UST Bonty Race TLR, so far its not come close to sealing and I'm having problems getting the sealent to stay in side the tyre.
Any clues as to what I need to do to get this combo to inflate ????
Posted : 11/03/2011 6:28 pm
