No hairspray for gr...
[Closed] No hairspray for grips?
[#1583473]
Mornin' all, I'm in the middle of replacing my grips to find the Mrs doesn't use hairspray, and therefore i'm at a loss.
Can anyone suggest a good substitute for sliding grips on and them sticking to the bars?
Cheers peeps!
Posted : 07/05/2010 11:11 am
WD40 has worked well for me in the past, as has GT85
Posted : 07/05/2010 11:31 am
GT85 never lets me down.
Posted : 07/05/2010 11:32 am
plug the hole on the end with the palm of you hand and push it on with the other - it will create a positive pressure inside the bar and do little fatrs but should glide on 🙂
Posted : 07/05/2010 11:33 am
GT85
Posted : 07/05/2010 11:34 am
WD40 - slidey at first, then keeps the grips stuck once it dries.
Posted : 07/05/2010 11:38 am
Depends heavily on the grip in question I find.
Posted : 07/05/2010 11:40 am
Trade the missus in for one who uses hairspray??
Posted : 07/05/2010 11:42 am
I use Damp Start silicon spray. Its used for sealing car ignition systems from moisture, but its great for sticking grips on!
Posted : 07/05/2010 11:43 am
Lock on collars.
Posted : 07/05/2010 11:49 am
I use Muc Off disk brake cleaner
Posted : 07/05/2010 11:52 am
The good thing about GT85 is that after a few re-fits it errodes the rubber into a super-sticky compound. Though I use lock-ons as it does less damage to the bars getting the grips off again.
Posted : 07/05/2010 12:02 pm
Did a search in the end and used washing up liquid!
Went on ok. seem to have stuck well too.
See you later guys I'm off to try 'em out!
Posted : 07/05/2010 12:27 pm
Enjoy while you can once they're wet again it'll have the same effect.
Posted : 07/05/2010 12:31 pm
Why not just join the modern world and buy lock ons?
Posted : 07/05/2010 12:36 pm
 scud
Renthal the motorcross company make a product called Renthal Grip Glue used on some dirt bikes, can be a bit to good sometimes though, would make sure you've got the cockpit set up exactly how you like it before using it.
Posted : 07/05/2010 12:38 pm
I discovered the GT85/WD40 grip softening trick too, makes them expensive, but my odi-yeti lock ons are now ohhh soo soft (but dont last very long, hence expensive).
Posted : 07/05/2010 1:11 pm
GT85 gives a more secure grip than the few lock-ons I've tried.
Posted : 07/05/2010 1:27 pm
Just go buy a small can of hair spray and keep it in the tool box along with the bike lube, brake fluid, etc
Posted : 07/05/2010 9:30 pm
Disc brake cleaner worked for me. they slid on very easily then dried quickly. got lock-ons now though......
Posted : 07/05/2010 9:47 pm
