Niner Biocentric Eb...
[Closed] Niner Biocentric Ebb v1
[#5985567]
Any hints on how to free one up?
I have undone the retaining bolt. I can get a couple of mm movement.
I have squirted loads of GT85 down the seat tube and left it for many hours to o avail
I rang Charlie the Bikemonger and he had a couple of suggestions but neither really worked.
In my simple and non mechanical mind I wondered whether it would be a good idea to take it out, put some copper slip between it and the frame, then refit it or.....wander down the lbs and leave it to their tender mercies.
Posted : 23/02/2014 10:12 pm
The one on my SIR.9 usually gets stuck in place over Winter.
I undo the bolt a few turns, then tap the bolt head a few times.
It does the trick.
Posted : 23/02/2014 11:38 pm
Permanently used copper slip on mine. Previous owner had done the same. Worked well. Remained free and no issues with it holding.
Posted : 24/02/2014 8:50 am
I had one that was properly seized due to rust. Used lots of WD40 to soak it in and then a blunt screwdriver and hammer to tentatively knock it out. Took ages but eventually freed it up. Then used oxylic acid to get ride of the rust and a little sandpaper. Now reinstalled with copper slip and seems to be working fine.
Posted : 24/02/2014 10:12 am
They are alloy so try not to knacker them with hitting them with a screwdriver/chisel 😐 I've not had one seize yet but it has been a bit stubborn, best method for me was undoing the bolt a little then a smack with a hammer from either end to and fro to ease it a bit, then back off another 1/4 of a turn on the bolt and do it again.. However I have stripped the thread in the EBB by over tightening so take care with that too... I had it helicoiled and it's fine now but hen I use it as a spare. I've a spare (not that one) if you need it, or get the new 2 bolt version for £80 off Charlie/Stif 😀
Posted : 24/02/2014 10:33 am
