A tiny headtorch helps for mechanicals and punctures
That really is good advice. I carry a Thrunite H01, which also has a firefly mode, turbo and SOS mode, not to mention a handy magnet.
Oh there's a Raveman adapter for GoPro mounts under out-front mounts.
Do they all have the car-friendly beam?
Do they (Ravemen) all have the car-friendly beam?
Yes, sort of, but in different ways. It’s a bit confusing.
PR-series (up to PR1600) = 2 x emitters (ie LHS = DuaLens ie road/gravel w/cutoff, RHS = MTB/torch)
PR2400 = 5 x emitters ie 1 x central ‘DuaLens’ ie road/gravel + 4 x MTB/torch.
CR Series = Single emitter. Varying beam-patterns depending on model*, ie ‘T-shaped beam’ or ‘DuaLens’**. All are anti-glare with side visibility
LR Series = Single emitter ie ‘Curved beam’ flood w/side visibility, no cutoff AFAIK)
* https://www.ravemen.com/t/Road%20cycling.html
** ‘Dualens‘
similar to automotive low beam headlight, providing broad close-range flood light with anti-glare cut-off line, no dazzle and glare for oncoming riders and pedestrians’ eg: https://www.ravemen.com/CR/CR900.html
Thread needs pics
I’ll sometimes pull over and spend ten minutes here or there faffing about shooting.
Here are a few, for other lunatics to enjoy 🙂
" alt="" />
