Night-riding headac...
[Closed] Night-riding headaches
[#5677391]
Ive been suffering from gripping frontal lobe headaches whilst night riding - no eyesight problems, dont wear glasses, using an exposure Diablo (helmet mounted), blinkie and constant modes, doesn't seem to matter... Any experiences / solutions?
Posted : 09/11/2013 12:55 am
Have you tried a different lamp?
Posted : 09/11/2013 9:30 am
Are you sure you don't need glasses? When was the last time you checked.
Also try a bar mounted light. Might just be tension from supporting a larger weight on your head. Also make sure nothing is pressing on your head. I have headache issues with glasses. Fine for a bit but if they are a bit tight after a few hours they start giving me a headache.
Posted : 09/11/2013 9:35 am
 rob
I get the same if using a helmet light and I wear glasses, put the light on the bars and my headache goes away.
Posted : 09/11/2013 9:40 am
Are you having to tighten the helmet up to compensate for the extra weight?
That's what occasionally gives me a headache when night riding
Posted : 09/11/2013 10:31 am
Yep, it's the weight. I get it at work when the blast visor and chin guard are in the up position.
Try moving the light back a bit to reduce leverage.
Posted : 09/11/2013 10:33 am
I suspect it's the weight.
The whole helmet becomes unstable so you either have to tighten it up loads of balance it more. I have been trouble free since going away from exposure to a very small, very light Four4th light Genesis 3 light with batter in my pocket.
Posted : 09/11/2013 11:06 am
 accu
had the same problem...
have the light now mounted more back on the helmet...
looks odd..but better leverage and everything is fine now...
[img] ?0[/img]
Posted : 09/11/2013 11:36 am
Thanks folks, gonna try a thinner beanie too, hoping its more the 'pressure' effects more than the eyesight or imminent haemorrhage theories...
Posted : 09/11/2013 5:11 pm
