Is the latest model number M785?
Also, I have a rear IS frame mount and a fork post mount. If I opt for 180mm rotors back and front, do I just need a rear post to IS mount adaptor and not a front one?
Thanks.
Posted : 22/11/2012 7:40 pm
Yes - M785.
It depends on what fork you have. Some forks will allow you to mount a 180mm rotor and caliper without an adaptor others will require one.
Posted : 22/11/2012 7:44 pm
Thanks dgb1, it's a 2011 Sektor.
Posted : 22/11/2012 7:47 pm
Sekto is the same chassis as the Revelation, which does need a PM to PM 180 adapter for my 180 rotors
Posted : 22/11/2012 8:11 pm
As above think you can fit 160 post mount without an adapter but you need to for 180 & 200.
Posted : 22/11/2012 10:12 pm
