I have a brand new shock (CC DBAir CS) and I can't seem to get it to hold pressure, it seems ok while static and even overnight.
I've submerged it in water but cannot see any air bubbles, it seems that when load is applied that's when it leaks air. If I pump it to 130psi after 5-10 mins of riding it's dropped to around 90psi
Otherwise the shock appears to work fine, it's not getting sucked down or anything but it keeps requiring me to pump it up throughout the ride to maintain pressure.
I haven't got a vice so haven't pulled the air can off (as if to add spacers), could there be an obvious problem here?
Any ideas?
Sorry if unhelpful but if it's new with receipts I'd be looking at warranty. Not great if they're gonna make you wait for a replacement though
Return it as its new.
Fair comments, I was hoping for a "quick win", I'll see how I go about returning it. Thanks!
you could put a small amount of air in the shock so you can compress the shaft and try the water again
Have you checked the valve? Just see if you can tighten it with a valve tool, that might be your quick fix - failing that, send it right back
The last one we had had a lock ring where the shaft went into the shock body, it could be tightened with a bottom bracket tool.
No matter what we did it continued to come a bit loose and loose air. Evenymtually it was swapped under warranty for an Ohlins which never gave me any trouble
That's disappointing, I thought the quality issues had been sorted with these now... obviously not
it could be the negative chamber balancing. does the pressure continue to drop?
Bookmarked. Leaky fox.
I thought that initially too. But cycling the shock and topping up the air it just keeps dropping.
I'll get in touch with the company and see if I can get a replacement, although it has put me off somewhat...
I wouldn't be put off, it could happen to any shock. It might just be a folded or unseated seal inside that just needs replacing.
I sympathise though as it's a right pain in the arse when stuff doesn't work out of the box.
that’s a pain. hope it gets sorted out painlessly and quickly.
