New shock.. bush re...
[Closed] New shock.. bush removal/installation.
[#7155916]
I'm thinking of buying a shock from ze Germans as the pound is stretching well these days.
Am I going to have to factor in buying a tool to remove the bushes from my current shock and install into new shock. I don't have a press but I do have a hammer.
Will I die?
Posted : 25/06/2015 9:29 pm
No, you'll proberbly knacker the new bushings though.
Buy the right tool. I got mine from BETD.
Posted : 25/06/2015 9:38 pm
Shock will probably come with bushes fitted. My new Monarch plus did. Just needed to swap the mounting hardware.
Posted : 25/06/2015 9:47 pm
Shock will have bushes, you just swap across the mounting hardware
Posted : 25/06/2015 9:58 pm
The mounting hardware being the flanged bushes which just pop out?
Any point buying new mounting hardware? No play in mine.
Posted : 25/06/2015 10:03 pm
If theres no play then reuse what you have
Posted : 26/06/2015 8:43 am
Ta very much all.
Posted : 26/06/2015 4:55 pm
I bought a tool of eBay
http://www.ebay.co.uk/itm/Shock-Bushing-Tool-for-rear-Fox-Rock-Shox-Marzocchi-2x-Polymer-Bush-DP-DU-/281714307455?
It came with 2 polymer bushes and if worked a treat, dead easy to use
and its really nicely made do should last, cost me £10.50 including postage 🙂
Posted : 26/06/2015 5:04 pm
+1 for that shock bushing tool sold via 'mowicu' on eBay, it's a very well made item and good value.
I can also recommend the 'heavy duty mount kit' from TFTuned:
http://www.tftuned.com/heavy-duty-mount-kit-127mm-m8/p2937
Even though your new shock probably has decent bushings fitted, and your existing hardware might be OK, for £15, you could just get a complete mount kit that is guaranteed to work well.
Posted : 26/06/2015 5:22 pm
