Hi All
First Post!
I have purchased an old Carrera Vengence from someone, im not interested in spending loads of money, its only to ride around Rutland water as I live very close to there.
I was part way through changing the gear cables when I rounded one of the little screws on the shifter cover, long story short, rather then mess about I am thinking of just changing the shifter.
It currently has Shimano ST-ef51-8r and I want to stay with the brake lever and shifter combo, unless someone can suggest otherwise.
Can I just change to Shimano ST-EF500-2 without any problems? I have mechanical disc brakes if that helps.
Or can someone suggest an alternative?
Many thanks for all your help
Yes, as long as the number of gears is the same then it'll be fine.
Thanks
