Yes, and it doesn't have to be tokens either - chuck some oil into the air spring of any fork and it'll reduce the volume and cause the rate to ramp up more quickly. My Soul has old Fox 32s which behave like this.
I didn't realise you could use the tokens in sektors, that is interesting. I'd forgotten about the BB height issue though, staying high up in the travel is going to leave the BB high up all the time isn't it? But still, I'd rather that than spend a grand on a BTR
Slacketst nu skool @ 130 is probably Whyte 905.
A fork should be set up to work well as suspension, not adapted to make up for shortfalls in what i'd like in terms of geometry.
[rose tint] Oh - and it wasn't so long ago that 120mm travel [i]was[/i] long travel & all this was fields........ [/rose tint] 😉
Stiffen the forks up, if you blow through travel too easy.
This.
I'm running 140mm RS Revs on my HT but on a typical trail ride it only ever uses about half the travel...which seems about right, why would you want a bike (even a full suss) wallowing in all of its travel for fairly tame trail riding?!
The fork tends to use full travel (or a few mm short) on uplift days only, that's with the air pressure put in that RS recommend on the fork leg, no buggering about with tokens either....I'm slowly coming round to liking air springs and their ease of tuning....i had similar performance from my old coil spring Sektor but that involved swapping the OEM medium spring out for a firm spring from TFtuned...which was obviously more hassle than just playing with a shock pump.
Tokens are now available for some 32mm stanchion forks like the Revelation but I wasn't sure about the Sektor but that's good to know as it's a good fork that performs better than it has any right to for the budget price.
Not having 29ers is the only reason I'm not looking at Bird 🙁
29er are perfect for your local stomping ground Ben.
You have to buy 32mm ones just to be clear... you cant use Pike ones, but the principle is the same.I didn't realise you could use the tokens in sektors, that is interesting.
Cheers Ben, I'll bear it in mind, not even got any RS Forks at the mo! Still got my crappy suntours
Thing is cokie I have some 29'er prototypes, and try as I might to love them, they just don't set my world on fire.
Sounds like you want some U-turn Lyriks, just dial in the travel you want between 115mm and 160mm. Performance stays broadly the same (ace) at all travel settings. The great news is they're available second hand for buttons due to the fall from grace that's hit 26".
I recently put some Totems on my Jekyll, set the rear to 95mm and the front to 135mm (2-step airs) and it made for a pretty cool setup, short travel, but ultra stiff. Too heavy for a hardtail I'd think, but the performance was exactly what you're after.
Yeah Paul, but what I want is the slackness that you'd get at 140/150mm at 100/120mm too. I'll have to blag a go on some aggro hardtails at varying degrees of slackness before I splash out.
+1
How slack is [i]slack[/i] ❓
2016 650b Orange Cloclwork 120 is 67' HA, which is the same as 2015 Crush (in an XC friendly unburly aluminum frame).
Isn't that what the angleset was invented for?
Angleset also lowers BB by X amount, in the current climate of [i]low[/i], that may be a bit too much pedal wackage.
Depends on the headset, if you currently run a ZS56 (The most common) then an Angeset will raise the BB a touch as the +10mm or so of the EC headset is bigger that the extra slack will cause in drop.
Qwerty, I want 66-67 at sag point, 74ish sta. there's plenty of choice of 66-67° static head angle frames, but I was caught out by that with my bizango. My rock rider full suss was too steep at 70° And I thought a 69° ht 29er would be better, and it is, a bit, but I think that's probably more trail than anything else, as soon as it points downwards sharply it gets a bit nervous, and the bars are already a bit high.
I can't use an angle set either, I'm going to have to bodge it slightly to get some decent forks in if I decide to upgrade the voodoo rather than replace, which I might because it's pretty bloody good for the money.
Well, I would consider taking one off your hands for a prolonged period!! If you don't get on with them then maybe I can make use of them 😀 ! Email in my profile 😉
Oooooooo, I like it!
The blue one please. 8)
Ooooooooo a blue one to replace my blue one. Even better 😀
Wow...i likey!
Any info on price,launch date and if there will be a black one on sale as shown last year??
...no front mech cable stop ??? 🙁
Gar, hadn't noticed that. 😐
Say what?
[url= http://www.mbr.co.uk/videos/bikes-and-equipment/best-hardtails-2016 ]From MBR:[/url]
[i]Like the DMR Trailstar, Orange’s re-launched P7 is also made from butted steel tubing and features 27.5in wheels, internal dropper post routing, ISCG 05 tabs to mount a chain device and is corrected for a 140mm travel fork.
The key difference is the P7 has the facility to mount a front derailleur, which is handy if you want a wider gearing range or you’re considering buying a frame and building it up with an older drievtrain.
Orange will be offering the P7 at £1,450 and it will share the same basic spec as an Orange Crush S.[/i]
I still really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really want one to replace my existing P7.
But after my recent Cannonade Trigger purchase, getting it past the committee may prove difficult 😳
Good price and great...who needs a front mech! 😀
Hmmm the MBR story is dated Nov 2015 so price could be a guess.
WTF are those cable guides?
That blue version is absolutely drool-worthy.
I reckon a shiny burgundy colour would probably necessitate me having a cold shower.............
Blue is the RS version with a dropper post hence the cable plus Rental fat bars,only differences i can see
[quote=steel4real ]...no front mech cable stop ???
None needed. Front mech cable can share the downtube routing and then use a Side-swing mech.
Way Over priced for Reynolds 525.
I want that blue.
Scotroutes>
In 10 speed ?.........and a bit of Google Fu = YES 😀
And I mistakenly thought they were only available in 11 speed !
Nice one.
Confirmed from orange that they're available in the next couple of months. 😀
I think it looked better in black and those dropper guides need moving to somewhere that looks less like an after thought
Saw them a the London bike show and still like,was told only 120 of the green P7S version being made this year...better get in quick!
Loving the renaissance off the slack HT, in years gone by you went to OnOne and bought a 456 of some description....now you've got the new DMR, Nukeproof, Ragley, Orange and still On-One (stalwarts that they are!)....good times, I bloody love a hardtail.
Talking to a friend who works at Orange, I think they may have sold all of their first batch of P7s already - August for the next lot. Worth checking though, by sold he may have meant sold to dealers. Or I may have misheard him.......!
That blue one looks lovely.
There seem to be some really good hardtails knocking about at the moment.
£1445 or £2345. Ouch.
