New Kona Kitsone = ...
[Closed] New Kona Kitsone = Old Blur 4x?
[#5203570]
I've been tossing around the idea of getting a new FS frame. 2 of my old faves were a Kona Coiler and a SC Blur 4X, now it looks like the new Kona Kitsune is an almost carbon copy (geo wise) of the Blur.
Anyone ridden one yet? I'm hoping it's agile but stable from the relatively slack HA, just like the Blur was!
Posted : 30/05/2013 4:15 pm
 hora
Bing. Im in
Posted : 30/05/2013 5:55 pm
Seen the Genesis Grapil? Transition Bandit, Blur TR, ASR5, Mega TR? All similar to that IMO.
Posted : 30/05/2013 6:37 pm
Blur 4x was only 115mm travel
Banshee rampant 100mm
Nukeproof rook 100mm
I have a rampant with coil sektors - its a little ripper...short back end, low, stiff, head angle about 67.5 with 140mm forks. shock is pushed tuned with makes it great.
Posted : 30/05/2013 6:44 pm
 hora
The Rook is 7.2lb?? Why so heavy
Posted : 30/05/2013 6:53 pm
daveh - Seen the Genesis Grapil? Transition Bandit, Blur TR, ASR5, Mega TR? All similar to that IMO.
Bike in looking like bike shocker!
Kitsune is 120mm, if the angles are right then I dont think the travel matters quite as much
7.2 isn't that heavy is it? Your meta is listed at 7.27lbs
Posted : 30/05/2013 7:04 pm
I wanted something similar and ended up tweaking a giant trance x to get close the the geometry.
20mm longer fork and an offset bushing, gives a 68 deg head angle and a bb of just over 13"
It is pretty close to what I am after, but still not the holy grail.
Posted : 30/05/2013 7:17 pm
The grapil looks good, I wonder how much it weighs? Being a tight wad I'll need to wait until something turns up used so that will go in the search box
Posted : 30/05/2013 10:21 pm
Just buy a Blur 4X? I loved my old one...
Posted : 31/05/2013 9:16 am
It's a slopestyle frame, designed to take a bit more of a beating than your standard trailmince-lite frame.
Posted : 31/05/2013 9:21 am
I too loved my old Blur 4X, I didn't love it's continual need for new bearings and the horrible tiny linkages (those independent Ti dogbone bits) that needed maintenance.
I'd hope that more modern frames would stand up to more abuse in the bearings and/or are easier to maintain.
Posted : 31/05/2013 9:41 am
 hora
I loved my old blur4x's the VPP1 had a quirk though (anyone else?) - if you stood up and mashed the pedals the suspension didnt like it.
Then MK2 VPP came out.. I wonder if this was a known quirk hence the tweak(?)
That was my only critism.
Posted : 31/05/2013 9:44 am
acjim - Member
Mine came with those - swapped them out for the solid link (SC made the solid link standard after a while too) and had no issues after that. I think a lot of people in the US got the parts free.
Posted : 31/05/2013 9:58 am
Mine had the solid link. The continual bearing/bushing changes was a bit of a chore... Never had a problem with pedal bob etc with it. Ran mine 1x9 though but do remember some bob in the granny ring when I was running it 2x9.
No idea if its any help but I went from the 4X to a new Five (as slack, little longer in the wheelbase and TT and a touch more travel). Its easily as good as the 4X was but without any of its negatives.
Posted : 31/05/2013 10:38 am
Old 4X'rs convention 🙂
Mine had weird pedal feedback in the granny ring, it was truly fantastic downhill though, took it to Verbier and rode out of my skin - nice memories!
A Five might be a goer, I've always thought of it as longer travel.
Posted : 31/05/2013 10:52 am
Old 4X'rs convention who took them to Verbier. Out there it was great... The trails and mid-30s heat did help though. I could have been riding a Halfords special and it'd still have been brilliant!
Try and get a ride on a Five. Like the 4X, they're as good as the hype I've found. Glad I changed...
Posted : 31/05/2013 10:57 am
