New forks, confused...
[Closed] New forks, confused, any experts?
[#10619471]
Last year I bought a Bird Aeris 120 frame and swapped the parts over from my Whyte 901. Ive been slowly changing/upgrading the parts. Next on my list is the forks. I'm quite well up with bike parts generally but I feel I'm going around in circles.
I need 140mm, 27.5, tapered steerer, currently have a non boost front wheel but after looking online are all new forks boost? If so I can sort out a wheel too.
Anyone seen any good deals?
I've seen these...
2017 pikes 130mm
Can they be easily changed to 140mm?
Or these...
2019 pikes 140mm £550
Anything else I should be looking at? Anything I should avoid? Help! Please.
Posted : 10/05/2019 11:15 pm
You can change most non boost hubs to be boost, what hub have you got?
Posted : 10/05/2019 11:20 pm
Also l'd look at fox over rock shox having used rock shox many times my fox 34 are buttery smooth in comparison.
Posted : 10/05/2019 11:23 pm
The front hub is only a Whyte own brand job
Posted : 10/05/2019 11:30 pm
Just get a boost spacer kit for about a tenner off ebay.
I got a mt zoom set and it works a treat.
Posted : 11/05/2019 12:05 am
Experts? Yep the forum is full of them 😉
Yes you can swap travel on 2017 pikes by swapping the air shaft maybe able to get a debonair upgrade one too, or one of the other systems that increase the negative air chamber volume ( smoother initial movement) luftkappe etc.
Posted : 11/05/2019 12:28 am
I've just read the description of the CRC 2019 one. And realised is has oneloc. This is a remote lock out? If so I dont think I'd ever use it and would clutter the bars. Can it be removed easily? Google suggests yes, no, it's easy and its difficult to do.
So let's say I get the 2017 I'd need a 140mm air shaft like This and then whilst I've got the fork apart I could stick in a luftkappe? How would this then compare to a 2018/19 model? Will I notice a difference?
This is what I mean it's a nightmare!
Posted : 11/05/2019 8:34 am
These things used to be so simple, then ‘Standards’ were Introduced to make things even easier.
Posted : 11/05/2019 8:38 am
It's so confusing most of the descriptions I read on the websites of the places selling them contradict themselves...
Posted : 11/05/2019 8:43 am
Go for crown adjust it’s a lot less faffy.
Your lbs may be able to do a deal on some forks/ price match if they talk to the distributor & advise & fit all parts to save you the confusion/hassle.
Posted : 11/05/2019 2:07 pm
Have a look at some x fusion forks.
Upgrade bikes have a pair slants 27.5 non boost forks will set them at the correct travel prior to dispatch for no extra.
Posted : 11/05/2019 3:02 pm
