New flat pedals and...
[Closed] New flat pedals and knee pain???
[#11495326]
I've recently chopped my Hayes Pro Taper platform pedals in for some Unite pedals.
On some pedal heavy rides I have been getting a really sore left knee, right on top of my knee cap.
Anyone had similar experience and any advice on how to try and prevent it?
Posted : 24/11/2020 12:13 pm
Modern flat pedals and shoes can be so sticky that you're effectively pedaling on an absolutely zero flat system
Posted : 24/11/2020 3:46 pm
Is your seat high enough... that usually causes top of the knee pain... it may also be that you're putting your foot on the pedal in a position that is not natural. Sit on the edge of a table and look at the angles your feet make and try and replicate that on the pedals when you ride...
Posted : 24/11/2020 3:51 pm
As per @zezaskar - you've probably ended up with no 'float' as your shoes are gripping your pedals so tight. I have found that certain shoe/pedal combos naturally try and force your foot into a postion due to the alignment of the pins and the design of the sole.
Posted : 24/11/2020 4:18 pm
Seat height isn't a bad place to look up as well, but don't discount pedal grip.
A similar thing happens to me when using Nukeproof Horizon pedals combined with Shimano GR7 shoes. The shoe-pedal interface tends to force my feet into a specific position. In long, constant pedaling this can be a little uncomfortable and I tend to readjust my feet periodically.
If knee comfort alone is your thing, I think Shimano SPDs still can't be beaten
Posted : 24/11/2020 4:34 pm
Thanks, I'm going to try pretty much all of this. I'll also experiment with some where my foot naturally comes down on the pedal and where it sits when I apply pressure.
Posted : 24/11/2020 4:54 pm
I was going to mention saddle height as well. I found the same when swapping to thicker pedals.
Posted : 24/11/2020 7:00 pm
