New disc rotors - s...
[Closed] New disc rotors - suggestions on supplier please
[#650822]
I'm running a 6" Hayes Stroker Carbons just now - brakes are very good indeed, stop quickly and seem to have a very nice feel to them. However, I've noticed as I tend to drag my brakes (as I'm a sh!tb@g rider), if I stop and then start again, the front needs a few good pulls to get the bite back.
I'm not entirely sure but I reckon it is overheating due to my poor braking technique so I'd like to go a size up on the front - looking at CRC, the 7" Hayes rotor seems to be rather pricey so I'm wondering what else is out there that can be recommended?
Someone has posted up about Ashima rotors but they look (to me) to have no braking surface so already in my head I'm convinced they won't be as sharp or powerful.
So what are the recommendations?
Also, I'm running Fox F120RL's with Post Mounts - I'm assuming I just need a post mount to post mount +20mm adapter? [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=17277 ]Like this one[/url]?
Any suggestions please on new rotors? Also, I reckon the HAyes rotors are ok, but if the suggestions are better, I'll probably also go for a rear improvement as well...but that will stay as a 6" job as the read brake is plenty powerful for locking up.
Thanks.
Posted : 21/06/2009 7:48 pm
I've been using the imperial ones from www.mtb-direct.co.uk on most of my bikes for a while now and they work well and are cheap as chips too. If you're going to change I'd go all the way to 203 while you are at it.
Posted : 21/06/2009 7:55 pm
These have been fine for me, quick free delivery too:
[url] http://superstar.tibolts.co.uk/index.php?cPath=50&osCsid=d763f574b655bc9d0b28552619d7658b [/url]
Posted : 21/06/2009 8:15 pm
Try this lot [url= http://www.discobrakes.com/ ]Disco brakes[/url]
Posted : 21/06/2009 9:04 pm
I have an Ashima rotor on the rear and its fine, I have not noticed a difference to the standard shimano one I was running previously.
Posted : 21/06/2009 9:21 pm
Alligator windcutter rotors from www.readytoridecycles.co.uk - cheap, and great service. Work great- again a minimalist design, but no different in power/use to the original shimano ones.
P
Posted : 21/06/2009 9:26 pm
BBB wavey rotors are almost identical to the Superstar ones and are pretty cheap. Come with stainless Torx bolts as well.
Posted : 21/06/2009 11:23 pm
Anyone have a contact number for Disco Brakes? Can get rotor and adapter for £18 delivered but it won't let me register to order - will order over phone if I could find a number...
Thanks.
Posted : 22/06/2009 2:59 pm
I find the Ashima rotors bite better than Hope.
...I remember when you used to slag me off for dragging MY brakes!
Posted : 22/06/2009 3:12 pm
DB, I doubt you'd be overheating your brakes by just dragging them a bit, I'd only expect brakes to boil over at 400 deg or so... Check the calipers aren't a bit sticky before shelling out for new rotors.
Posted : 22/06/2009 3:24 pm
also a2z rotors from the woolyhatshop.
Posted : 22/06/2009 3:30 pm
more likely your pads need a change, if your cooking your brakes dont use sintered, go for a good organic
Posted : 22/06/2009 4:51 pm
or possibly you have air somewhere in the system
Posted : 22/06/2009 5:04 pm
