They're not on here yet, so I don't expect anywhere in the UK would have.
When I enquired to https://conti-tyres.co.uk/ about availability of different tyres, they said stock will appear on their site for direct sales first (expensive, and expensive postage though). It then goes to their wholesalers and then on to retailers – takes 2-3 weeks from when they come in at conti-tyres.
EhWhoMe
Full MemberAnyone having issues with weaping side walls, my rear trail casing it weaping out in loads of places mainly at the small center dot on the embossed patteren..using stans.
Mine inflated and stayed up without air, which is about the least Continental thing I can imagine.
Without air? What did you do, fart in it? 😀
anyone seen stock anywhere?
Kryptotal 29x2.4 Enduro
Rubber_Buccaneer
Full MemberWithout air? What did you do, fart in it? 😀
A late response, but, god DAMN it!
So, China prices. Anything imported from German has a high import tax, but still....
Trail Endurance 27.5*2.4 (produced here?) £49
Enduro Soft 27.5*2.6(German?) version £60
I am absolutely fed up with Maxxis Wobble suffered by almost every single Maxcis tyre I own. Continental and Schwalbe (Magic Mary) tyres are easily (although expensive) available here. Is this what I should be moving to?
Kryptotal 29×2.4 Enduro
@BearBack I just got an alert from r2-bike that they have the front and rear enduro soft in stock again.
Looks like the front has already sold out again though!
I’m actually waiting anyway after hearing in a podcast that a supersoft trail casing front is on the way.
I've been using the trail ones for ages now. For full on enduro use.
Been really impressed. I am light though
First ride with a Kryptotal Re Trail on the rear today, replacing my summer Dissector instead of the usual DHR2 (EXO MaxxTerra) for winter.
Trail centre muddy hardpack, mud, and roots. Running the same 22psi as usual (I'm 75kg), it felt maybe a bit stiffer than the DHR2/Dissector so might try 1-2psi less. As I was coming from the Dissector I didn't ride it back to back with the DHR2, all I can say is it felt good, the only thing I noticed was it felt faster rolling than the Dissector which itself is faster rolling than the DHR2. I can't attribute it to the tyre alone as I also had a new rear hub, but I beat pretty much all my previous times on downhills, technical and fire road climbs.
Since getting the Cushcore Bead Dropper lever I no longer hate tyre inserts, so I put the Rimpact Original in after all. No problems fitting, pulled the last bit over the rim using just my hands on XM481 rim (no tyre levers used at all, just the Bead Dropper to stuff the bead under the insert), inflated with normal pump. It looks narrower than the DHR2 but that's only because it's squarer; the edge knobs don't curve round so much.
Handy. I was after a burlier Dissector type thing for after the winter so ordered a Xynotal, alongside a Kryptototal which if it really is a faster rolling Big Betty Supergravity then I’m quite excited about it for ham fisted year round rock clobbering and the winter.
@luket any comparison of the Kryptotal vs. Xynotal? Given my new winter rear is faster than my previous summer rear, not sure whether to keep the Kryptotal for summer or find something even faster.
I’ve been using the Xynotal 29x2.4 Enduro Soft for quite a few months now. Wanted a tougher casing than I usually run for Dyfi in the summer. Sadly I slashed the sidewall with a freak landing from a drop thing in Tony the Tiger (Climach X) and wrote it off. Put it down to bad luck and bought another one and very pleased with it. Running it without an insert - don’t think I need one with a tyre weighing about 1150g.
Rolls ok and so far it’s doing alright in the wet / muddy conditions that are edging their way back. Will continue running it until it gets too slippery - got a trail / endurance Kryptotal Re that I ran last year for proper mud. I think now that’s my 2 rear tyres to cover all year round tbh.
Ive just stuck an ultra soft Kryptotal front DH casing on for BPW in a few weeks. I wouldn’t normally buy a tyre like that but when I slashed the tyre at Dyfi there were limited options to buy at the bike park. I tan it on the rear that day but curious to see how it is on the front. It’ll be coming back off after uplift as it’s too much tyre (circa 1300g and draggy) for me to pedal round.
Either run a Wild Enduro or Hillbilly once the summer finishes - been running the wild enduro for a few months and generally like it. But the Hillbilly (t7 grid gravity) is unbeatable so far in the mud for me.
@bikesandboots no I'm afraid not. I haven't used either yet. I'm still battling along quite successfully with a now heavily worn Big Betty. I'm looking forward to a faster tyre but I refuse to take this one off til it's really knackered and after 2 years of serial tyre swapping and flats the Big Betty is tough as old boots!
Just to compare the Kryptotal re in trail / endurance with the Xynotal in Enduro / soft the Kryptotal has chunkier tread and I don’t think from memory that they are ramped like the Xynotal.
So it’s definitely a slower rolling tyre - but vs my usual winter rear (2.3” dhr2 maxterra / exo) it finds a lot more grip in thick mud. Even in the snow on the Mendips it kept going up a few hills where my mate was spinning out his dhr2. I didn’t notice that the harder compound was particularly slipping on any roots more than the maxterra dhr2 I was running before it.
On the front I’d want a grippier compound than endurance though - soft in Conti seems about max terra like for me. Shame they don’t seem to do that compound with the trail casing as that would be ideal on the front.
