New chain - degreas...
[Closed] New chain - degrease or not?
I'm not worried, I'm just interested. Isn't that why we read and post on forums? And actually I learnt that the compromise solution makes the most sense to me now that I'm not assuming it's packing grease.
Posted : 21/02/2013 7:16 am
I only asked because I wasn't sure I could be arsed to degrease and relube a new chain before tonights ride. The irony being, that a/ reading this interesting thread has taken longer than the job and I'm still not much wiser whether I should or not, and b/ when I went out to the garage the bikes developed a case of seized jockeywheel-itis anyway, so the singlespeed's being dragged out instead. And we know the chain maintenance routine for that.......
Posted : 21/02/2013 8:21 am
I wondered similar a while back and found this intervew on bikerukour.com
Taken from this page http://www.bikerumor.com/2011/06/28/chainwear-challenge-quick-interview-with-shimano/
I took the opportunity to ask one of Shimano’s main tech gurus, Nick Murdick
BikeRumor: What is Shimano’s official stance on the chain lube that comes stock on a shimano chain? Is it actually a lube, or a grease? And is it best to leave it on until the chain gets noisy and relube, or strip it right away and relube before riding?
Nick: So that brings us to lubrication. I mentioned that the chain wears because of friction as the chain moves to wrap around a gear. Well, that friction is reduced if there is lube on the chain. If there is dirt mixed in, the lube makes a bigger difference in reducing friction. If there is water mixed in, the lube helps displace the water. The grease that comes on a Shimano chain is applied at the factory to the individual pieces before the chain is assembled. The grease does a better job of reducing friction than aftermarket chain lubes and it lasts longer. The main reason we use liquid chain lube, whether it is one that stays liquid or a dry lube that has a solid lubricant in a liquid carrier (like a PTFE lube) is because we need to get the lube on a part that is not accessible without disassembling the chain. So the best thing to do when installing a new chain is to leave the factory grease on, not apply any other lube, ride until it wears out and then start applying liquid chain lube. In dusty conditions you can wipe off the outside of the new chain with a rag that is wet with a gentle degreaser to keep dirt from sticking to the grease. The factory grease also keeps the chain nice and quiet. After soaking a chain in degreaser and then lubing the chain with liquid lubricant the chain gets noticeably louder.
Shimano does not have an official recommended chain lube. They all seem to work pretty good. Different people have different preferences and different conditions require different lubes.
So there you have it. You absolutely should leave the original chain grease in place for best performance, and there are differences in construction that were necessary to make up for the narrower 10 speed chain. So far, those differences seem to be working as the 10 speed groups are still slightly better as far as wear, but it will be interesting to see how it plays out in the end!#
Posted : 21/02/2013 8:32 am
Page 2 / 2
