New bike time - Ibi...
[Closed] New bike time - Ibis Ripmo AF
[#11192464]
My Ripmo AF NX build arrived Tuesday. I spent the afternoon fitting the invisiframe kit so Wednesday was the first ride out.
Swapped out the 150mm dropper for the 170mm brand x from my other bike and I’ve bought some SLX 4 pot brakes to swap out the guide t once the bits arrive.
I’m a couple of rides in and when I first jumped on it the seated position felt really weird as the SA felt a lot steeper than my 2018 YT Capra despite on paper being the same. As soon as I hit a climb though that feeling disappeared as where on the Capra I might shift my weight forward on the saddle a bit I was already in the perfect position. The way it climbs is actually pretty amazing as it’s not light yet on steep climbs that I struggled to clear on my 120mm Scott Spark, I’m climbing up pretty easily on the Ripmo AF. I’m not having to struggle to keep that balance between rear wheel traction and stopping the front wheel lifting up. Just sit and pedal, easy.
Point it downhill and it picks up speed so quickly and just wants to pop off of every little thing. I really think this bike is going to get me in a shit ton of trouble but I couldn’t be happier with it.
Posted : 14/05/2020 9:14 pm
“Swap out” ffs
Posted : 14/05/2020 9:17 pm
Posted : 14/05/2020 9:21 pm
what the travel on that? looks lovely, enjoy!
Posted : 14/05/2020 9:28 pm
Nice. Did it come with an Aggrressor out back, or did you swap it out?
It’s 160mm f and 147mm r travel.
It’s comes with 2.5wt exo+ Assegai front and rear. I swapped out the rear assegai for the aggressor and keep the other assegai as a spare.
BTW the Assegai is insanely grippy. Tron bike cornering with that on the front.
Posted : 14/05/2020 9:33 pm
Rad bike  you must be stoked  looks sick what cockpit are you running how do you like those apples @mulacs
In all serious, they are awesome bikes. Congratulations didnt fancy the coil?
Posted : 14/05/2020 9:37 pm
I originally wanted the coil but had an email chat with dvo and they recommended the air shock as I’m on the weight limit of the 550 spring.
Tbh the topaz air is super smooth and supple so I can’t imagine much benefit from the coil for the extra weight.
Posted : 14/05/2020 9:43 pm
Looks bloody brilliant! Keeps us posted on how you get on with it.
The Ripmo AF is on the shortlist for my next bike and looking at the spec the only thing I would change is the brakes and the rear tyre too.
Posted : 14/05/2020 9:55 pm
Yeah, Assegai is a brilliant front tyre, just seemed an odd spec choice to put it on the rear too. That's about the only grumble though, it's fantastic value.
Posted : 14/05/2020 10:02 pm
TBF the brakes are ok, I just prefer Shimano levers
Posted : 14/05/2020 10:22 pm
A few of the 'merkin youtubers ride the ripmo's and they love them. Would like to throw my leg over one.
Posted : 14/05/2020 11:11 pm
Looks badass! Probably my top choice if I was getting a full-sus right now.
(And a great bike for proving that bike weight is so much less important than almost everyone thinks!)
Posted : 14/05/2020 11:41 pm
 tdog
Totally true chief ! 👍
One of my bikes is 40lbs &
Oddly enough it's not a Surly no!
Posted : 14/05/2020 11:51 pm
 tdog
Oh very sweet ride too Op
I was gonna go af route but went impulse in a good way the DH route coily coily for me
Posted : 14/05/2020 11:52 pm
I think my biggest concern was that it would feel sluggish uphill or when pedalling along flat sections but quite the opposite. There’s a section of trail which is a fairly mellow gradient but it’s really rooty and on my other bikes I’d have to be out the saddle otherwise I lose momentum as the bike gets hung up on the roots, but the Ripmo just allows you to sit and pedal and keeps going forward.
Should also mention how impressive the DVO suspension is. I’ve generally ended up with Fox performance stuff as I don’t spend enough to get the elite or factory stuff. The feel of particularly the forks is noticeably better then anything I’ve had before and that they managed to get that on a bike that costs under £3k is superb.
Posted : 15/05/2020 8:49 am
A friend has a ripmo (none AF version), and I have a 2018 CF pro capra. I've had a few goes on it, its an impressive climber thats for sure - and goes downhill well.
Posted : 15/05/2020 8:56 am
Interested in the coil shock comments. Was it just that they don't make a heavier spring for that shock? Or do they think the amount of progression doesn't suit a larger/heavier rider on a coil?
Posted : 15/05/2020 8:57 am
The 550 is the heaviest spring they currently make (I think). They said I could get a heavier spring from another manufacturer but said the shock would also benefit from a retune to get the best out of it. Which tbh sounded like a load of time and money I wasn't keen on spending.
Posted : 15/05/2020 9:08 am
 Alex
Looks good. I’ve ridden the V2 briefly but would be nice to properly compare it my V1. I did like the (DVO Air) shock on it though. I was in the process of buying one for mine when we went into lockdown.
Posted : 15/05/2020 9:15 am
If it's not too personal a question, what does that make the upper weight limit?
That looks ace. These are making their way up my potential next bike list.
“Swap out” ffs
Attempted new bike stoke removal. Way to break rule 1.
Would have to try a lot harder than that as the Stoke level is off the charts
I’ve obviously been watching too many bikemag and Pinkbike videos.
Posted : 15/05/2020 9:19 am
Rode a reign on DVO shocks in Vancouver, they are next level....
Posted : 15/05/2020 12:01 pm
I’ve potentially sold my hunt wheels from my last bike.
I’m going to buy an SLX 12sp groupset. Does anyone have any experience with SLX 12sp? It’s been a few years since I’ve used a shimano groupset as all the bikes I’ve had have been specced with GX or NX, but always much preferred the shimano feel so keen to give it a go.
Posted : 15/05/2020 7:41 pm
 tdog
@wzzzz - just you wait till you ride try on BOS forks
It'll blow your mind
Posted : 15/05/2020 8:37 pm
I bought an af nx build as well a few months back and changed everything to new slx. It’s miles ahead of the nx in feel. I hated the nx feel, it lasted about 1 week on the bike I think. The 4 piston brakes are fantastic, very powerful.
Sold the bike since because it felt sluggish to me ☹️
Posted : 15/05/2020 9:08 pm
Very nice. I just finished up building a bike around a discounted V1 frame.
Posted : 15/05/2020 9:36 pm
If it’s not too personal a question, what does that make the upper weight limit?
The upper limit on the ibis quick set up says 230lbs for the 600lb spring. I’m around 240.
Posted : 15/05/2020 9:59 pm
Great choice OP! These bikes are the bomb! Suspension is so sorted. Coming from a Transition Patrol Carbon, it may not be as light, and possibly wont be so good over distance and multiple long climbs, but my god it smooths out the trail. Dunno if its the DW linkage or the DVO, but it works well. DVO front, although initially in a car park might feel a little sticky, is superb on the trail, at least as good as my old pikes+vorsprung (and better than my pike ultimate on HT, which I cant get right). The coil is so good. So simple and works a charm. I'm on a medium with 400lb spring (70kg naked :D).
I find this bike as playful. I find it poppy, which is contrary to coil preconceptions.
I've basically rebuilt my bike aroudn the frame and forks, and sold all the original bits. Ended up costing me £200 more for a very high spec bike. Its 33.8lb now.
Posted : 15/05/2020 11:47 pm
When the Ripmo came out I thought it seemed such a sorted design apart from the head angle being a bit steep, plus I don’t want a carbon frame - then the AF arrived and it ticked all the boxes. It’s only now that other brands are picking up on the value of not just short seat tubes but tons of insertion depth so you can run big droppers.
If I get sick of my full-sus having a motor then I shall get one! I can’t cope with having three bikes, it’s hard enough swapping between two, and I like riding a hardtail too much to not have one...
Posted : 16/05/2020 12:01 am
@muggomagic
Lovely looking bike mate and you are right to be well chuffed.
Where was the first pic taken btw? SDW?
Posted : 16/05/2020 12:19 am
@superfli Looks great. Have you noticed the weight savings when riding?
@CGG I’m the same. Too many bikes and I find that I end up not enjoying any of them as they all end up feeling a bit weird, so I tended to just use the one anyway.
Hence going back to this rather than the Izzo (as well as my general carbon angst).
I want one bike that I could ride pretty much everywhere. I’ve kept the Capra with the thought of using it on uplift days but not sure I wouldn’t just use the Ripmo now. Maybe I’ll buy some triple clamps forks and build the Capra into a DH bike 😀
@poopscoop thanks bud. Yes, it’s SDW above Steyning. There’s a load of great trails in the woods just up the hill a bit from where that picture was taken.
Posted : 16/05/2020 7:33 am
Lovely bike Muggo, looking forward to seeing it out on the trails when group rides are allowed again.
Posted : 16/05/2020 7:49 am
Cheers, hopefully not too much longer now.
Posted : 16/05/2020 9:06 am
I need to get myself over to Steyning, I'm qecp local. Muggo, I swapped the parts out from new, so can't say whether I'd notice weight savings. Got one more but to change, and that's the wheels. The Ibis wheels are really good and the asymmetric rims are lovely and wide, but I got dtswiss envy when riding my mates bike and have a set of 240exp hubs on pre order, so I can build up a quality set (prob on xm481, as carbon is too expensive).
Posted : 16/05/2020 9:23 am
Makes sense. I thought about upgrading the wheels to the carbon when I ordered the bike but when I looked it up there was only like 200g in it so didn’t think it was worth the extra money.
I need to get myself over to Steyning, I’m qecp local
They’ve done so much work up there over the last couple of years. It really is a fantastic riding spot.
I’ve ridden a few of the southern enduros at QECP you’ve got some mint trails over there. Especially the ones they’ve used for the Day Night race.
Posted : 16/05/2020 10:00 am
Unfortunately they are currently being demolished by the forestry 😢
Posted : 16/05/2020 11:18 am
 tdog
Good to see prioritising decent tyres over carbon rims
Posted : 16/05/2020 12:21 pm
Ah crap. I had seen something about that on the QECP Mtb Facebook group but assumed that was the Buriton stuff.
Posted : 16/05/2020 12:36 pm
Well pleased with the Assegai and Aggressor combo.
Posted : 16/05/2020 12:37 pm
I'm currently considering the Ripmo AF or Carbon but can't decide between Large or XL.
What size are you and what frame did you go for?
Getting a test ride on one is near impossible
Posted : 25/05/2020 11:49 am
I’m currently considering the Ripmo AF or Carbon but can’t decide between Large or XL.
I can imagine demos aren’t going to happen for a while. I’m 6ft with 32 inside leg and I’m on the large. The geo charts show that it has very similar reach and stack height to my 2018 Capra which is perfect for me, so I was certain it’d fit and it does. It has a really low stand over height though so if you like a longer reach I would think it’d be no problem sizing up.
Posted : 25/05/2020 12:11 pm
Thanks I'm nearly same size as you so that's helpful, I do like the longer reach I've tested a few bikes with 480+ reach and I like them.
Carbon has a 500mm reach in XL but figure I can dial with back with a shorter stem if needs be.
Posted : 25/05/2020 3:10 pm
6ft with a 34in inside leg. went XL. can't imagine fitting on a large, i'd imagine the reach being too cramped. personal opinion
Posted : 22/06/2020 2:56 am
