New Bike Day... the...
New Bike Day... the not so Enduro race speedy carbon bike
@julians
Indeed mate yeah... it's something i've been considering. At the end of the day, the Trek is awesome for 99% of things i can do.... it can arguably do the other 1% along with 50% more... .but of course i'm the limiting factor. It would be nice to be able to get it a bit more plush though, but it'll still only be 130mm of travel compared to the 160mm on the status.
At the end of the day i don't expect to be racing again anytime soon, but of course i will be at places that require a bit of bouncy.
The Trek feels more 'neutral' i guess to ride compared to the slightly 'out there' front end of the Status...
But i could honestly ride either on a regular basis.
Posted : 15/06/2022 11:55 am
Well that's interesting... Apparently you can't get spacers to fit the Reactive Thru-shaft shocks.
Posted : 15/06/2022 12:38 pm
is thats why its for sale.....?
https://www.pinkbike.com/buysell/3361444/
what have you got your eye on next?
Posted : 15/06/2022 4:28 pm
is thats why its for sale…..?
It's not exactly for sale, it was more out there in a potential swap scenario, the pricing i've put it up for i wouldn't realistically expect to see, so was more hypothetically up for swap.
I currently have an offer of a swap for this.
https://www.pinkbike.com/buysell/3360828/
But don't know how much he'd want his way yet...
I guess i'm kinda thinking that now the enduro side of things has gone a bit pear-shaped, then a bit more bounce. However since i posted that i've now ordered the 150mm air-shaft for the Trek which is currently at my LBS being installed as we speak... So i really need to make my mind up here 😀
Posted : 15/06/2022 4:40 pm
He wants £500 to jump to the Megatower. It's an interesting thought... but... Mmmmm
Posted : 15/06/2022 5:15 pm
Isn’t your Trek a better spec than that mega tower? Also probably newer / seen less use etc. Both have nice expensive carbon frames. Mega tower is meant to be a little bit plough I think - but if that’s what you’re after it’s a really capable bike.
Posted : 15/06/2022 5:20 pm
3 months ago:
After sitting, thinking, listening, reading advice on here and deciding, i thought “well, the stuff i’m riding, i can/should be fine on something less massive than the big blue bouncy G170.
Now you want to swap to a megatower?
Also odd that he wants to swap to your Trek when he states:
JUST A DO IT ALL RIG ONLY MARKS ON BARS FROM STRAPS FEW ON BRAKES COMES WITH DOCUMENTS MIGHT TAKE A TRADE ON OTHER BIKES IF TAKES MY FANCY IE EBIKE , ENDURO , DOWNHILL 29ER PREFERRED
Posted : 15/06/2022 5:29 pm
I take his advert being all in capitals as a bit of a warning sign the seller might be a total berk. Also that he’ll swap for almost anything is a bit odd.
Posted : 15/06/2022 5:34 pm
Don't we all do the "maybe i should...." then 3 months later "maybe i ought to....."
Maybe it's just me.... At the time of swapping to the Trek, it seemed the right plan and in many ways it still does... but i do wonder if for some stuff i need some more bouncey...
But maybe the 150mm will give that tiny bit more anyway.
Posted : 15/06/2022 5:37 pm
I'm not sure adding 10mm travel to the fork will revolutionise it
I love a shorter travel bike, and I love tweeking them.
Not saying I'm right, just that I have one possible solution.
I think I'm similar to you in riding for fun primarily, occasional race not taken seriously. No massive jumps or drops.
I've currently got a fairly low sag percentage, no volume spacers in the fork, coil (therefore linear) at the rear.
Rode Swinley last night following hardtain on the weekend, pumping through the rollery bermy bits, felt like rolling on a cloud.
25% sag means I've got 75% left to play with, and I'll regularly use nearly all of it.
Others stuff a load of tokens/bands into a long travel 170 bike, run it at 30% sag, and never use the end of the travel because its so progressive. Check the maths, and we have pretty similar travel used.
Of course they have a bit more negative travel for some ground hugging traction, and a safety net for when they finally build up to hitting that drop and cock it up. But day to day riding...
Different geo, thats a whole new kettle of fish though.
Posted : 15/06/2022 5:57 pm
I’m not sure adding 10mm travel to the fork will revolutionise it
I absolutely agree... but then again, it's not £500... it's £75 all in and i can live with that for a potential small gain.
TBH i'd happily throw a coil in this, but i've got some weird funky setup on the bottom of the shock with a weird mounting.
[img] ?strip=all&lossy=0&ssl=1[/img]
So i don't know what or how would actually fit it... There's nothing i've found online about replacing it.
Weirdly TFTuned told me the spacers can't be used like in a normal shock because of the ThruShaft, but then a google search implies it can....
Shocks though i do like 'squidgy'.... more so than most, 40% i'm happy with that on a DPX2 for example and they do run quite soft at the early part of the stroke.
Posted : 15/06/2022 6:06 pm
That’s a weird ass shock lower mounting
Posted : 15/06/2022 6:14 pm
So i don’t know what or how would actually fit it… There’s nothing i’ve found online about replacing it.
Looks like there's plenty of space around that lower mount though? And google suggests it's a standard-ish shock size (210x52.5). I'd be surprised if a coil shock wouldn't physically fit even if it needs TF to make you a really long spacer kit.
Weirdly TFTuned told me the spacers can’t be used like in a normal shock because of the ThruShaft, but then a google search implies it can….
Is it just the photo or does that look like a really small air can for a 210mm shock? Have they done something clever and taken length from the air can and added it to that wierd lower mount which is why it cant be reduced further?
Posted : 15/06/2022 6:29 pm
It’s only because Trek use their proprietary thru-shaft design.
The Fuel EX uses a stock 210 i2i size shock (52.5mm stroke from memory of my old one). You can actually fit a 55mm stroke shock on it, which will give you ~137mm travel.
You just need a mount kit to make it work.
Posted : 15/06/2022 6:30 pm
I guess the issue would be to get the threaded mounts at the bottom end. Top end liiks standard trunnion.
I'll email TFT again about the volume spacers and link them the article.
https://www.mtbr.com/threads/volume-spacers-for-2020-fuel-ex-rear-shock.1129721/
https://m.pinkbike.com/news/trek-fox-thru-shaft-shock-review.html
But that one is a bit different to mine
Posted : 15/06/2022 7:00 pm
https://flic.kr/p/2nsgw6D
Treks suggested settings.
Posted : 15/06/2022 7:04 pm
So i didn't go with the Megatower, despite the fact that in the 5% of situations it'll probably be better than the Trek, in the 95% the Trek will blow it out of the water..
So i'm just waiting for the LBS to shout me and will collect my forks.
Sadly, it seems we're unlikely to be racing this weekend due to an A&E visit for the lad all night, it's ended up being nothing serious but he's barely eaten for 3 days and can't even get out of bed. So the odds of him making it to FoD on Sat/Sun are pretty damn low. I could of course go race on my own, but the reality is, i was only racing for the laughs and banter with my lad rather than for a result in the race.
Posted : 16/06/2022 9:40 am
@hobnob it seems you're very much correct mate. Thanks for the pointers
Chatted with TFTuned who tell me you can fit a standard eyelet shock.
https://www.tftuned.com/tf-tuned-mount-kit-127mm-trek-bikes/p3791
you need some of these.
https://www.tftuned.com/trek-rear-shock-pin-to-trunnion-hardware/p3518
some of those..
and of course a shock... it then runs a standard type shock 210*52.5. Hmmm interesting..
Posted : 16/06/2022 11:27 am
Sounds good if you can stick a normal shock in there.
If going air I’d be inclined to look at a Cane Creek Kitsuma Air probably
If coil then there are loads of good options - I like my CC Kitsuma coil (I’m still working on the settings / coil weight side of things) - it seems to pedal well and on road / fireroads the lockout lever is actually insanely locked out vs other shocks I’ve had. Fully locked it feels like a hardtail.
On roots and stuff it’s so plush - down corkscrew / ski run / sheepskull I’ve never ridden it so fast and so much in control as I did on Sunday. My bike has 150mm of rear travel though.
Posted : 16/06/2022 12:16 pm
air/coil/external res or not... all decisions i need to consider.
I need to borrow an external type to make sure it'll give clearance for water... i'm pretty hopeful looking as the frame, but i'd need to be 100%.
I absolutely loved the feel of the Bomber CR on the G170, but obviously at 850gr it's a bit weighty... but the Trek is light anyway so may not be a major issue.
After chatting with TFT it's possible a couple of volume spacers may work too.
But in honesty i'm a little scared to do it... I think doing volume spacers previously i've actually caused more issues than i've resolved, although i still can't understand how or why.
I did the bands on my RS Monarch RC3+ and that broke soon after, i did another Fox which then failed and then another Fox which then failed soon after... But i can't see how or why me fitting spacers would do that. One of them was working perfectly until i did it, i don't think i even swapped any on that, i just released the air, checked and then re-inflated, with incremental compressions to cycle it etc. Once inflated it then wouldn't hold air and squatted.
I know that's all a little irrational, but hey that's where my head is sometimes.
Posted : 16/06/2022 12:24 pm
It cant be that long till your Alps trip. have you decided which bike you will be riding
If it was me I would run what I have, until after then. At least you know what you have and any limitations. I think the extra travel in the fork you are doing should be a good move for the type of riding involved.
I've seen too many peoples holidays spoiled as they have done changes too near or for the trips and found out too late that its made the bike worse.
Just finished the final fettle for ours next week. New tyres on one as they should have been swapped 12 months ago and have very little tread left. New saddle on the Enduro curtesy of the classifieds and a front brake blead on the Stumpy, again should have been done last year.
For us holidays should be as little fettling as possible and repairs if necessary
Posted : 16/06/2022 12:38 pm
Excellent point. I'll be on the Trek in the Alps as I'll leave the Status set up for the lad and over the majority of my trails the Trek will suit me best anyway.
Posted : 16/06/2022 12:53 pm
Re any shock upgrade have you actually considered how it  would suit the suspension kinematics? If the frame is specifically designed for air shocks you could find a coil too linear and blowing through travel, a progressive spring etc may help but your starting to blow a lot of cash chasing something you may not get (which has happened before).
Posted : 16/06/2022 12:55 pm
Outside of my knowledge levels on how to even begin with that mate.
I did consider a dpx2 on PB at £275 which if it doesn't work I could sell on again so I'm then only out of pocket the price of fitting kits
Posted : 16/06/2022 1:00 pm
You've been deliberating about the travel of the Trek from pretty much the first ride, despite telling us how happy you are with it. I think in your own mind, you will never really be happy with it.
Just sell it and buy another Status 😉
Posted : 16/06/2022 1:23 pm
Worth factoring in another £150 for a custome tune. Always worth factoring in the cost of a service on a second hand shock anyway, so a little extra to get it setup nicely for you and the bike just makes sense. I got the DPX2 I bought of you tuned after a while and it made quite a difference (admittedly the suspension on the G160 is an oddball, but still . . . )
STR, apart from the swap, no one showed any interest, plus, I have status.
Posted : 16/06/2022 1:43 pm
 Yak
Or look for a shock that you can tune to suit, eg DVO Topaz. You have positive air chamber volume adjust, negative air chamber volume adjust and an air bladder instead of an IFP in the piggyback to shift the spring curve up or down. Then you can get into the shim stack if you want, but the first 3 tuning variables are very easy to adjust.
Posted : 16/06/2022 1:45 pm
I did consider a dpx2 on PB at £275 which if it doesn’t work I could sell on again so I’m then only out of pocket the price of fitting kits
I'd err on the side of getting something new* and custom tuned even if it doesn't have the resale value. IME getting my very basic Fox RP2 on my Pitch custom tuned turned it from a horrible bike to faultless (apart from I then apparently blew it up twice, but the tune was fine). Getting another shock with the same factory tune won't make a difference unless you've found a fundamental fault with the current one, like you do need adjustable air volume, or it spikes, or you want adjustable LSC, or you find you need H + L rebound dampers (even if ones internally set).
*or 2nd hand, and get it serviced and tuned if it's a bargain.
Posted : 16/06/2022 2:04 pm
the other option is £500 and get the Megatower lol
Posted : 16/06/2022 2:10 pm
I don’t think I’d be doing that on the mega tower - hasn’t your top fuel got better specced forks / groupset etc already and had a much shorter life in terms of riding so far?
You could just stick the Top Fuel on eBay with a buy it now / best offer next time they have a discounted selling fee offer on. Probably the best way of getting good money for it.
Posted : 16/06/2022 2:41 pm
LOL i was mostly kidding with that matey 🙂
Forks are the same, but the wheels on mine are carbon. However they're not crazy light carbon according to reviews, more carbon in name than anything.
On the shock side of things i'll likely just wait a little while and try the 150 forks first, get used to them and then see.
Posted : 16/06/2022 2:45 pm
I’d be curious to have a little go on your Fuel Ex to see what it’s like - especially back to back with my Sentinel. I did wonder about a Fuel Ex when I was looking but couldn’t find a frame only in alloy - the carbon was too expensive frame only.
I didn’t think your G170 was that plush suspension wise - but then that’s probably due to being setup for you not me. I’d imagine you’d find the sentinel suspension too soft now with the 450lb coil on it. I’m still debating going up to 500lb but going to have a session playing with hsc first to see if I can work out if it’s bottoming out on drops or hitting a harsh spike of too much hsc dialled on.
Posted : 16/06/2022 2:56 pm
Of course. Sadly this weekend is now off. The boy still hasn't gotten out of bed since Monday afternoon apart from going to hospital last night. So even if he's ready mentally, I ain't letting him race at the weekend.
Which in truth means I'm not racing either, I'm not going to drive to FoD in the rain to race a course and come last on my own lol. It's father's Day too, which meant me and him we're out together, so I won't be leaving him at home and going playing.
Weekend after though if you're still doing Staunton/wherever has potential. I may be in Peaks on the Sat on wife's ebike, but Sunday that weekend I'm still free.
Posted : 16/06/2022 3:04 pm
Well it's unlikely anyone could tell but the 150 shaft is in there
[url= https://live.staticflickr.com/65535/52151198753_005af62bc7_5k.jp g" target="_blank">https://live.staticflickr.com/65535/52151198753_005af62bc7_5k.jp g"/> [/img][/url][url= https://flic.kr/p/2nsqwtc ]2022-06-16_05-21-45[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
Posted : 16/06/2022 6:26 pm
Out for an early one to 'beat the heat'.
[url= https://live.staticflickr.com/65535/52152700639_8183c61cb0_5k.jp g" target="_blank">https://live.staticflickr.com/65535/52152700639_8183c61cb0_5k.jp g"/> [/img][/url][url= https://flic.kr/p/2nsydVM ]2022-06-17_06-49-43[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
Out for an early one to 'beat the heat'. Forks work really well, but in honesty i'm not convinced someone of my level can tell the difference between 140-150mm. Either way, i had an excellent little test.
[url= https://live.staticflickr.com/65535/52152457501_12de2a152a_5k.jp g" target="_blank">https://live.staticflickr.com/65535/52152457501_12de2a152a_5k.jp g"/> [/img][/url][url= https://flic.kr/p/2nswYDK ]2022-06-17_06-49-31[/url] by [url= https://www.flickr.com/photos/152318156@N08/ ]Steve Weeks[/url], on Flickr
Should be able to soften them a bit more, so just whipped 10psi out, see how that feels next. I do like my forks softer than most would
Only disappointment was with Strava.. not because i care about where i am in the world, but i did want to compare my own ride against my own ride. But sadly it doesn't think i rode the same segment on ANY of the 3 runs, despite the fact it's a single trail that you really can't do any other way.
"Why it Did Not Match
Your Activity seems to have deviated from the Segment at 41%. We could not complete the match."
Ummmm if it had, i'd be lying in a tree by now
Posted : 17/06/2022 8:02 am
What device are you using to record your activity? You need a dedicated device that records data points per second.
Posted : 17/06/2022 8:39 am
Yeah my Garmin 520 broke not long ago, smashed the screen to bits and then it completely died, so i'm just using the phone.
At the end of the day i only Strava about 10% of my rides, and these were specifically for testing the difference between the Trek and the Status, so i'm not too worried about replacing the Garmin in honesty. Overall, i guess the results don't matter and they both really are pretty unexpected, the Status feels more plush than the Trek and the Trek in many ways feels faster.
I do really like both bikes, but overall i like the Trek more, it's possibly not quite as good in the tough stuff, but every other aspect of riding, it's better. It's also a chunk lighter, which at my weight, adding a bit more mass to the bike on hills really does have an effect, so i'd like to keep away from that 🙂
Interestingly this morning i also noticed i prefer lower pressures than i thought. I've been running 25-27psi in my tyres for a while now since reading how many pros in Enduro don't run 20ish... but today i dropped it after the first run to 'something' which after checking was 18.9 and i much preferred the lower pressure.
Sadly, the weather isn't going to play ball any more this weekend and with the lad being out of action, i don't think i'll be riding much for a few days.
Posted : 17/06/2022 8:45 am
I’d not be using Strava for any sort of accurate measuring. I’ve tested different devices on the same ride with often large variances. I’ve also done plenty of road rides with mates (so riding together), again with time variances.  At best it’s a guide, but it’s not good for accurate performance data over a 30s - 1min DH run.
Posted : 17/06/2022 9:19 am
yeah absolutely, i was going to use my lad and our phones and shout GO at the top and get him to time me... but it was 5.30am and he wasn't even remotely going to get out of bed at 5.30am 😀
Posted : 17/06/2022 9:21 am
I've started behind a mate on a long DH section, overtaken him and finished a good bit ahead - Strava had him beat me
Posted : 17/06/2022 1:15 pm
I’ve started behind a mate on a long DH section, overtaken him and finished a good bit ahead – Strava had him beat me
Yeah i think we've all had that previously with Strava.... i didn't think it was going to be fully scientific 🙂
Anyway, the Trek is getting a decent jaunt tomorrow now as i've just entered the uptonogood ride, 35 miles... mostly trails i ride fairly regularly off the Ridgeway, round Ilsleys, Harwell, etc etc... Will give it and me a decent workout.
Posted : 17/06/2022 1:18 pm
Have you got any sort of go pro/action camera?
watch the footage back and look at the time stamps passing a consistent start and stop point to get a fairly accurate time.
Posted : 17/06/2022 1:52 pm
Decent idea mate yeah, but essentially this was only to decide which bike to race Sunday on. As the race is now off theres little point worrying.
As a side note and bike to bike discussions, I have an option on this at £180
https://www.ebay.co.uk/itm/165530606088?_trkparms=amclksrc%3DITM%26aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Da0fddbdf4f094640a13f62b273c835a3%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D165530606088%26itm%3D165530606088%26pmt%3D0%26noa%3D1%26pg%3D2380057%26brand%3DMarzocchi&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A547fc67a-ee35-11ec-8721-d267c9468cc9%7Cparentrq%3A718ae0f91810a0f2c7fa1ba0fffede36%7Ciid%3A1
The fitting kits top and bottom end are £96. I technically need 4 kits, 2 sets of spacers and top and bottom bolts.
That still only take the price to £280 which isn't bad in all fairness.
It's certainly a consideration but looking at pics here it's a very very close fit!
https://www.vitalmtb.com/community/coregrind,26162/setup,42792
Add to that there's discussion on whether the progression curve suits a coil. So I'm currently a maybe.
But it's Friday afternoon which means it must be beer o'clock, which may be good or bad.
Posted : 17/06/2022 2:07 pm
I had a Google and couldn’t decide if the fuel Ex was coil compatible or not. That Cane Creek shock in the link has a progressive coil spring on it by the looks of it. Cane creek are 36mm diameter coils so smaller than the likes of Rockshox - although Fox are usually 35mm so assuming marz are the same it should be ok.
The only other thing is will the bomber piggyback clear the downtube? The bomber cr has pretty much the longest piggyback going and on my Sentinel it wouldn’t have cleared the downtube at full compression.
The Dvo Jade X has pretty much the shortest piggyback when I was looking. The CC Kitsuma has big blocky dials but the piggyback doesn’t extend down much so that fits pretty easily for me. DHX2 Fox also ok.
Posted : 17/06/2022 3:32 pm
Page 3 / 5
