Enjoying this thread, I'm waiting until I got the spare funds! I was reading somewhere that the bamboo should be at least 3 year old? Something to do with its strength.
Cheers, Steve
Skankin_giant - the bamboo should be at least 3 year old? Something to do with its strength.
When the bamboo is green it's filled with water, bamboo structure Is like loads of tiny straws compressed together - you can see the dots of the cross section in the photo earlier in the thread of the end of the tube. The wetter the bamboo the more flexible it is - remember that bit in crouching tiger hidden dragon where they fight in the bendy bamboo forest? But once it's dried out its pretty solid, but from what I've read the quicker you dry it out the more unstable it is.
Yeah there's a lot seems to have been written about bamboo for bikes and Fishing poles (some of it quite contradictory), from what I can tell, flame isn't actually intended to dry it out, you can apply heat to help seal it/kill the naturally occurring bugs and mould, and reduce the risk of it splitting or warping later, but application of heat has a fair chance of splitting it straight away...
and drying is really a case of letting it hang somewhere possibly using some type of desiccant to draw moisture out.
Apparently it losses a bit of diameter when drying (around ~5%) which would be a bit catastrophic if it dried and shrank, once assembled into a frame... I have a bit of a plan now, some notional geometry I want to produce and an ever growing BOM that I might start pulling together soon...
Cheers OP this has been an inspirational thread...
Great work. Lookin forwards to seeing the finished bike.
Those joints are starting to look really good.
Ended up wrapping the seat tube junction this afternoon - can't touch it untill Wednesday night now... then more sanding and fitting the bottle cage bosses and I should be done.....
Bought some 130mm O.L.D carbon clinchers in the end - not my first choice of wheel for this build but worked out a bit cheaper than getting a set built (and less hassle).
I'm thinking about calling it 'Cafe racer' after the coffee in the epoxy 🙂 just need to work out a way of writing it on the frame.... (carefully with the dremmel and more coffee/epoxy?).
I'd also like to epoxy in a head badge of some sort.
epoxy a coffee bean into the final wrap for a head badge?
Cheers, Steve
I could do that but I don't think it'll stand out on the lug which will already have dark brown blotches- I was thinking of bending up some solder into shat I want, paint it over with some thick epoxy and sand it back to flat (if that makes sense)....
Ah didn't think of that, could always gold/silver leaf the coffee bean first......
Cheers, Steve
Oooo just found these (pewter?) Coffee buttons which would work - 27mm across so not to large (for a head badge) either.
I was also having a think earlier about how to finish the dropout ends of the bamboo - decided to try some brown Sugru - never really liked the 'finger print' finish you get with sugru, but it'll be nicer than car filler or similar.
SAND PEOPLE!!!!!
The headtube (wrapped on saturday) was dry enough to unwrap tonight looks a little messy again, to be expected. And there's still some low spots where I don't want them, but it's sanded back nicely.
I also put some leftover epoxy/coffee mix in under the electrical tape wrap which seems to have worked.
If I have to do another electrical tape wrap I'd used coloured (green, red, blue) as trying to pick out tiny bits of black tape was a pain.
I used slightly thicker hemp string I ordered a while ago (stupid China post) rather than the thinner 1mm stuff I've used on the second wrap around the stays/seat tube. So each jojng will be slightly different from the others.
I'm hoping that I've left enough space for one of those buttons between the cable guides / eyes.
Excellent stuff, looks great & thanks for sharing.
A 25.4 seatpost arrived in the post today, surprise surprise it doesn't fit. Quick check with the Calipers ands it's closer to 26..... luckily it was a cheap trial seatpost.
So i'll either get a 26 or a 26.2, but i'll wait until I finish the sanding so that I can get so good measurements.
Also I have a choice of bars now, some traditional drop bars or some planet x mungo (mustache bar).
Another 20mins work on it... and it's slowly getting there.
[img]
[/img]
[img]
[/img]
[img]
[/img]
I used a different 1mm hemp string on the seat stays which gave a tighter wrap but... It doesn't sand as well. I think that as it was tighter it didn't soak up the epoxy as well so when it's sanding it's furring up.
I'll try to so more work on it and post photos of the seat stays etc over the weekend, but I've family down so can't promise anything.
This is ace. Very tempted to build myself a road frame.
Just be prepared to spend a lot of time sanding!!
I'd be tempted to use woven carbon fibre on the joints. That hemp looks hard work.
I built a canoe a few years ago. That is something I'm quite familiar with. 😀
I may use some carbon in the next one......
The button 'headbadge' turned up in the post this morning, same size as a 2 pence piece so about spot on.
[img]
[/img]
Also paid the customs charge on the wheels which should turn up on Tuesday.
I'm hoping to get some more of the finer finishING done later today and will update if I can.
Right, a bit more sanding and this is where I am....
[img]
[/img]
[img]
[/img]
I had to cut a few slots in the back of the button and bend it a bit to get it to sit nicely on the headtube and it still needs a little more work
[img]
[/img]
If your wondering whats left to do, there's the fine sanding and filling. I could just give it a final thin coat of epoxy and build it up at this stage.
[img]
[/img]
Wheels turned up today. Gave me a chance to check the alignment and is out by 2<3mm so no biggy. Somthing the horizontal dropouts can deal with. There us also masses of clearance as the back - may be able to run 38c tyres!
Wheel are also much better than I thought for £250 China carbon jobbies. 1580g....
Looks great! DIdn't fancy the matching Bamboo rims :O
https://www.etsy.com/uk/listing/123023756/bamboobee-bamboo-veneer-rims?ref=related-0
Cheers, Steve
Looking good there Sir, this is a great thread and I'm really enjoying watching you go through your labours of love.
What are the forks you are putting on it? They Bamboo too????
Skankin_giant - at £92 each no thanks... They also give no info on how they are made....
bikebouy - What are the forks you are putting on it? They Bamboo too????
Well I have got some carbon disc road forks on order. But now I know I can fit much wider tyres ill swap them out for some cyclocross ones. Is love a set of the new Lauf gravel bike forks but the be way out of my budget for this bike.
Decided to do some of the finer filling with Miliput (epoxy putty). I've done half of it and I'll do the other half later on and will post photos.
Sean Conway is riding round the whole of the UK coastline on a bamboo bike.. He's currently somewhere on the NW scottlandish coast
Right, while I wait for the milliput to cure, I've ordered the majority of parts for the rest of the bike (bank holiday discounts and all that).
So the full build will be......
Frame: Bamboobee 'XC' kit
Fork: TBC - ive a carbon road disc fork which should arrive in the next week, but this will change to a cyclo cross one pretty quickly.
Headset: Chris King
Stem: cheap one I got from Plant X in the sale to try for size (110mm)
Bar: either On One Mungo bars which i have already or Salsa Cowchippers (depending on drop required for fit).
Tape: DEDA leather look (brown)
Seat post: cheap one 26mm dia...
Saddle: Brooks Cambium
Brakes: TRP Spires - 140mm rear (i hope it'll fit, if not i'll swap for a 160mm) and 160mm front. Cane Creek levers
Gear lever: Dia compe ENE 10sp thumbie
Chainset: Sram Apex set up single ring with a 39t ring.
rear mech: Sram GX 10sp (should work with the thumb shifter as its not indexed).
pedals: Shimano SL road
Tyres: Conti Cyclocross Speed 35c - need to get hold of some 23 or 25c tyres though for the current fork.
oh and 2x fabric cage-less bottles.
Quick update...
[img]
[/img]
[img]
[/img]
[img]
[/img]
Miliput done (the otange bits) and so is the fine sanding on the seat tube junction it should look like this when the final layer of gel coat is applied (just sprayed with ipa fir the photo).
Run out of 240 grit paper so I can't do any more today.
Update: the wife tells me the forks have been delivered at home - mockup build tonight!!
Also the fabric cage less bottle has arrived so can get the bottle cage bolts in which will be a bit scary as it involes drilling into the down tube and seat tube and the screwing in the recessed bolts.... 😕
Not managed to do an update for awhile as im waiting on the parts to arrive so I can do a full build 'dry run' prior to the final finishing coat. I'll try to get the bottle cage mounts and cable guides in later on today.
Right - update....
When I bought the frame kit I bought some 'bottle cage inserts' which are a little Ikea in fashion if you know what I mean:
[img]
[/img]
Essentially you drill a couple of 6mm holes (spaced correctly)......
[img]
[/img]
and screw them in with a bit of epoxy to fix.
[img]
[/img]
The downside is that it lifts and splits the top
Layers of the bamboo around the insert.
[img]
[/img]
If I were to use them again, I think I'd wrap the areas around the 6mm holes in a few lengths of hemp prior to screwing them in.
Getting them in has ment I've sorted the cable routing properly - I'm using some double cable guides from crc in conjunction with Fabric cage less bottle mounts. I like to carry a single bottle but have the option to run 2 on hot days So I had to make sure that the bottle mounts would fit with the cable guides. This ment swapping the bolts for some longer ones and grinding down the heads so they'd fit in the bottle mounts.
[img]
[/img]
[img]
[/img]
[img]:/i1092.photobucket.com/albums/i404/skinheadjc/Mobile%20Uploads/2016-05/20160515_142249_zpsegq2d3nq.jpg[/img]
Any way.... starting to do the dry build as the parts start to arrive.
[img]
[/img]
I'm not happy with the fork - it doesnt sit right with the chris king headset, obviously made for tapered headtubes so i'll probably swap that at some point. It's also very very close to the 160mm disc (like 1mm close).
Fitted a sunrace 11-42 10speed cassette - I'll be running a single 39 or 40t chainring (depending if I go narrow wide) which will give 0.9 gear inches in the bottom end - same as running a 36t caste with a 34t chainring. ~ it's hilly in the cotswolds!!
I've also ordered new bars and stem - some Love Mud bombers and 31.8 stem.
All the remaining bits 'should' arrive by next weekend so I'll be able to do a full build to check for clearances prior to stripping down again, making any adjustments, final 250 grit sand and a coat of gel coat.
All colours of crazy that.
I like 8)
Oh yeah - forgot to give it some IPA shine before the photos....
To be totally fair, whilst I admired the effort I thought it looked quite horrendous. But, once mocked up in to a full build styley, it has grown on me massively.
Touche good sir.
Yeah - bamboo bikes always look terrible until they are built.
Will you leave it that colour or paint it?
It's going to be left with a clear layer of epoxy gel coat on the joints at least, although i've not sourced this yet. Haven't decided if i'll wax or varnish the bamboo.
The joints look quite light in the photos above as they are dusty - it'll darken up with the gel coat layer.
I could paint the joints but I don't see the point in that - I'd rather keep its 'home made charm'.
I'm still waiting on my box of bits to appear - I did have a sram apex chainset on order (was due into the shop yesterday), but I've just swapped this over to a deore so that I can get the thing built. I've also ordered a 40t ring to go on it.
After the first few bits have gone on I've noticed that the drive side seat stay joint is blocking the chain line so i'll have to sort that out this weekend.
I'm hoping that the rest of the bits I need will get dispatched today and delivered tomorrow.....
That looks so much better than I expected at the start of this thread, even in its part-built guise. Which Chinese seller did you go with for the wheels?
The wheels were these:
[url= http://www.ebay.co.uk/itm/272212494694 ]link to ebay.[/url]
It'll be a complete Frankenbike when it's built with a complete mix of mtb / road / touring & cyclocross parts.
Great, thanks.
Enough of my bit turned up today to start building it up.
First problem is that the diacomp thumb shifter didn't come with the shims for my bar... Started to make one out of some tube but it wasn't thin enough so i'll have to sort out something else.
2nd problem the chainset came without the bb.... guess that's another £10 ill have to spend.
3rd problem the forks are just too tight for
The 35c tyres I want to run. I'm guessin they'd be fine with 28's so I either need to compromise on the tyre size or swap the fork out. But as I didn't like how its sits either the headset anyway - the fork has to go! I may get some cheap 23c tyres just so I can get it rolling in the mean time.
4th issue was that tyre clearances at the rear are also tighter than I'd like. With the wheel slotted all the way in the horizontal dropouts the tyre has about 1 or 2mm either side - enough for the little rubber manufacturing spigots to buzz on the frame - I'll need to possibly run bmx tensioners to get the wheel to sit securely.
5th issue, with the 140mm disc on the rear I need to remove the rear caliper to get the wheel out - not great if/when I puncture. This ill need to some thought into as I don't think I could run a 160mm disc - but we'll see....
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
Wow looks great
