New bike, crank &am...
[Closed] New bike, crank & bb question?
[#10431466]
Just received my new bike and giving it the once over. The frame has a 73mm BB and comes with a Raceface bb and crankset installed.
There appears a gap between the crank arm and the bb though on the non-drive side, is this normal looking? From what I can read 1 spacer on the drive side is correct.
I’m used to Shimano hollowtech jobbies previously where everything sat pretty flush. Not even sure if I need special tools to tweak this setup?
[url= https://i.ibb.co/wSH9q0h/ABFB2-B51-ACF6-4-EF8-9246-13-D60489-F7-C9.jp g" target="_blank">https://i.ibb.co/wSH9q0h/ABFB2-B51-ACF6-4-EF8-9246-13-D60489-F7-C9.jp g"/> [/img][/url]
[url= https://i.ibb.co/Cmm8tDW/740027-AF-7-F96-43-BE-8-CBB-EF4-AF117043-E.jp g" target="_blank">https://i.ibb.co/Cmm8tDW/740027-AF-7-F96-43-BE-8-CBB-EF4-AF117043-E.jp g"/> [/img][/url]
Posted : 10/01/2019 9:48 pm
Give it a good, firm shove to see if there's any play - if there isn't, particularly axially (in/out) then you've got no worries. Given that RF BBs are generally made from cheese, it won't be long before you'll need another anyway.
Posted : 10/01/2019 9:55 pm
Doesn’t look right to me.... I’ve got - an admittedly older - race face bb and crank and it sits flush, no gap
Posted : 10/01/2019 10:36 pm
rf cranks tighten down onto a shoulder on the spindle do they not? not the bearings. If no obvious lateral play I wouldn't worry. I ran mine with a spacer less than recommended so as not to side load the bearings
Posted : 10/01/2019 11:35 pm
Thanks guys, I'll give it a good waggle and see how I get on.
Posted : 11/01/2019 1:29 pm
So that's a new BB??
Whoever installed that is a bit of a gorilla!!
Posted : 11/01/2019 1:41 pm
