New bike build - Co...
New bike build - Component Advice
[#12648129]
Hi all,
I'm in the process (slowly) of building a new bike to get me back riding after an accident. I've always just made old stuff work; now I'm embracing boost etc with a New Stanton Slackline frame.
So far I've picked up some 2023 RS Pike 140mm forks, some Hunt Proven wheels and a Oneup dropper. I'm planning on using some old SLX brakes and a Thomson stem.
Initially I was going 1x12 SLX group set but I can find one. what other choice should I consider. Also saddle. What saddle? I lover the Brooks C17 but Ergon look nice.
New Bike
Posted : 12/12/2022 2:46 pm
Initially I was going 1×12 SLX group set but I can find one. what other choice should I consider.
what hub driver is on your already purchased wheels? unfortunately Sram and Shimano cassettes are now a different fitting.
Although one brand's mech will shift on the others cassette, you are probably (for best value for money) looking at buying a full drive train as you are starting from scratch.
Posted : 12/12/2022 2:50 pm
Good point. Shimano HG. I’ve a 1x10 existing cassette and shifter that would fit but I’d like 1x12 ideally.
Posted : 12/12/2022 2:55 pm
SRAM cassette and chain and the rest from whatever flavor of Shimano you prefer.
Posted : 12/12/2022 3:19 pm
If it's an HG freehub then I'd go for a Deore rear casette.
Posted : 12/12/2022 3:32 pm
SRAM or Sunrace for the 12sp HG cassette if on a budget.
Garbaruk cassette if you want something a little more bling and want a weight  saving.
Mech and shifter would be SRAM / Shimano based on preferences and budget/availablity.
Stick with the brooks - it works for you, don't change now as youll probably regret and go back to a brooks.
Good point. Shimano HG. I’ve a 1×10 existing cassette and shifter that would fit but I’d like 1×12 ideally.
Other than more expensive consumable parts what are you expecting from 12sp ??
11sp Shimano will slot straight onto the HG and you can do Sunrace 11sp as well.
Posted : 12/12/2022 3:46 pm
Are you wanting 12 Speed for the range?
If so, microshift do the 10sp advent x rear mech, shifter and 48t cassette for a little over £100. I have it and it'd been faultless. I'd always go with 10sp over 12 Speed for durability and replacement cost.
Posted : 12/12/2022 4:01 pm
If you have an HG freehub then Shimano 12 speed cassettes won’t fit - not even the deore 12 speed one as that’s micospline. You’d need Sram NX or Sunrace / another alternative. If you can then afford sram GX or higher I’d go for sram - but shifter / mech wise I wouldn’t buy sx or nx personally - they aren’t very durable.
Deore 11 speed fits and they do an 11-50 cassette I think it is - so plenty of range. Sunrace also do wide range 11 speed cassettes.
Posted : 12/12/2022 4:28 pm
Deore 11 speed fits and they do an 11-50 cassette I think it is – so plenty of range.
11-51
https://bike.shimano.com/en-EU/product/component/deore-m5100/CS-M5100-11.html
I’ve just put one on my gravel bike 🙂
Posted : 12/12/2022 4:42 pm
NX 12 speed cassette will slot onto your HG rear hub, get GX or higher for the rest. Take the time to understand and fit it correctly, or get a shop to do it for you, and forget about it.
Posted : 12/12/2022 4:48 pm
Can't you build your groupset piecemeal on Merlin? they don't have a full groupset, but seem to have most of the individual elements in stock.
In experience the pricing buying individually is no more expensive than buying a groupset
SLX is a great choice, but seems to play well mixed w SRAM too
Specialized Power saddle
Posted : 12/12/2022 5:27 pm
Really happy with a full NX group at £200 Inc cranks. The rear mech is supposed to be fragile so will upgrade to GX if needs be eventually. Still cheaper than SLX (which is also excellent).
Posted : 13/12/2022 9:21 am
I had an NX rear mech OEM, and it needed constant tweaking, and ultimately committed hari kiri into the rear spokes. I replaced with an SLX. SLX is totally fit and forget, not had to adjust in 2 years and 1000 miles. No issues mating w the NX shifter
Posted : 13/12/2022 8:44 pm
