New 1x drivetrain -...
[Closed] New 1x drivetrain - 10 or 11 speed?
[#7590342]
I need a new drivetrain for a xc/race hardtail (its currently single speed).
Should I consider XT 10 speed with a wide range cassette (like sunrace), or an 40t expander which might be a bit cheaper, or just go for XT 11?
Posted : 20/01/2016 11:03 am
Can your current hub take a 10 sp cassette?
Vs £ of new 11 sp driver for your existing hub?
2nd hand 10sp shifter can be picked up easy enough.
As can a new XT 10 sp 11-36 cassette and chain of choice.
Superstar and others do a 40t expander for £25
If your rides are v hilly and you're on a 29er then a 42t may be better.
The only thing I'd like being on 10 sp is a 10t on the cassette but am willing to go without.
Posted : 20/01/2016 11:33 am
Shimano MTB drivers work with both 10 and 11 speed Shimano cassettes. Only SRAM MTB 11 and road 11 need a driver swap.
OP: I'd go with XT 11, less faff.
Posted : 20/01/2016 12:43 pm
 br
[i]an 40t expander which might be a bit cheaper,[/i]
Won't be cheaper.
If you're having to buy everything, just go 1x11, although you'll probably be able to use your existing cranks.
Posted : 20/01/2016 1:38 pm
This.
Peruse the German sites, you can get XTM8000 mech, cassette, chain and shifter for around eu200.
Posted : 20/01/2016 1:46 pm
If you need an expander it's about as much to just go 11 speed (like for like with XT) and be future proofed. The Germans were cheapest when I got mine.
I figured it out as £159 for mech, 42t cassette and shifter from bike-discount and a 105 chain from Merlin for 11 speed versus £145 for 10 speed XT from bike-discount. If you get a 40t 11 speed cassette they work out the same price.
Posted : 20/01/2016 1:50 pm
Rather than fiddling with an expander just get a sunrace 11-40/42 10 speed cassette?
Posted : 20/01/2016 1:53 pm
I would go for 1x11 XT if you are replacing everything. No point going for 10 speed then bodging with an expander cog when a properly designed solution is available. 10 speed was great and I have it on 2 bikes and wont be changing it any time soon but the shifting on my 11 speed is much nicer.
Posted : 20/01/2016 2:02 pm
 adsh
You may find 10speed and standard 11-36 sufficient. It's what I run with a 30T up front and I don't find it limiting. By the time I'm spinning out it's generally quicker to freewheel and unless you're doing SDW etc the 30-36 will get up most things.
The main advantage is an XT 10sp 11-26 is quite a lot lighter than it's 11speed twin.
Posted : 20/01/2016 2:05 pm
That was my thinking a XT 10 with a praxxis 11-40 cassette would have the same range as 11s but it would be lighter (roughly the same weight as 11-36.
Posted : 20/01/2016 2:24 pm
