Need to renew my tu...
[Closed] Need to renew my tubeless setup - which system?
[#7472794]
My 5-6 year old BMX inner-tube ghetto system finally failed yesterday when my inflator pulled the valve out 🙁
So I need to redo both wheels (Mavix 717 & 719) - should I go with Joe's No Flats or Gorilla tape ghetto? If the latter, which tubeless valves?
Posted : 23/11/2015 9:17 am
I'm using the superstar valves with electrical packing tape bought in eBay. It apparently it's the same tape stans use but you get a massive roll for ten pounds. It does appear to be exactly the same and works really well. Do some googling and you'll soon find it. Gorilla tape works well but I found the stans copy tape is smoother and makes tyre fitting easier ?
Posted : 23/11/2015 9:49 am
Had the 719's running fine with Stans tape and Stans sealant. Using the stans valves too. Been solid.
Posted : 23/11/2015 9:57 am
Superstar tape seems alright too, used it on three or four wheelsets and only had trouble with one wheel so far, possibly due to poor workmanship.
Posted : 23/11/2015 10:25 am
Ghetto 24" tubes for me. Quite like the all in one nature and eliminates leaking around the valve which I sometimes get.
Posted : 23/11/2015 11:16 am
I've got a minion non lust on a Mavic 321 that has been tubeless for over 3 years using electrical tape (cheapest £1 for 10 rolls type stuff) and a dose of eBay liquid latex, using a Mavic valve.
Apart from the tyre now being shagged out, it has been absolutely perfect.
Worth a go without spending lots.
I've some mates who just cut the valve out of an old tube and use that without problems too.
Posted : 23/11/2015 11:51 am
