Need press fit 86 a...
[Closed] Need press fit 86 advice.........
 jeb
[#9525486]
Hello
I am looking at this frame, with press fit 86 mm bb:
https://www.bike-discount.de/en/buy/cube-attain-gtc-race-frame-carbon-n-white-642376/wg_id-6868
Can i use this BB? :
http://www.ebay.co.uk/itm/Wheels-Manufacturing-Bottom-Bracket-WMfg-PF86-92-Out-22-24-22-24-mm-Black-/152509524146?hash=item238246a8b2:g:GLoAAOSwU8hY75T5
-but i wondering, is it possible to get some converters for the bb 86, and then run normal hollowtech 24 mm bearings .... ?
Thank you
Posted : 01/09/2017 8:18 am
the '22/24' thing suggest it's a GXP BB, to fit Sram, although it doesn't say that it the title. Obviously depends on what crank you'll be fitting.
AFAIK the WheelsMfg BBs can swap out the bearings. The standard Shimano BB86 BBs can't (like all Shimano BBs).
Posted : 01/09/2017 8:30 am
 jeb
I will run some older 105 cranks! -guess it is 24mm.....!?
Posted : 01/09/2017 8:34 am
