The line that drops towards Teggs Nose Country Park and the ons directly from it are. If you keep right at the bottom of the err bottom one, then right again that'll take you all the way down past the reserviours and all that's legit. If you go right then follow the road round to the left it'll take you up Hacked away Lane which is a steepish rocky climb, then on Tarmac all the way up,to the start of Charity Lane.
The others? No, not legit but it doesn't stop people ridding them
Email?
Carlos
The track that drops straight off the nose, is really good, but it looks to me like people are sessioning it on big bikes as some really deep carves are developing. I think it's probably a pretty sensitive place to ride.
M6TTF - those ice photos look amazing. That was a pretty epic winter all round. Wish we could have a bit more of that frost this year!
Are we talking from langley to teggs or teggs to langley?
Christianscook@gmail.com
cookci - Member
Not sue on the question?
Alex - Best ridden in the dry or frozen solid. The drop past the wilderness library is another good run off the top. Not as quick or steep but good enough (except for 1x gate) and brings to out at the gate before the climb up Hacked Way Lane
coockci - I'll mail you later when at home with a route or 2 that should keep you interested and help you to link stuff up.
I haven't tried that for years actually - I'll pay a visit when the ground firms up a bit.
so the "three shires" bit....
i need to ride past the entrance to cumberland brook (which would be on my right)
then go left after the corner on the a54 then left again onto the descent then climb back up to the A54?
does that sound right?
Personally I'd opt for the Quarries loop instead but if you go right at the end of Danebower, then take the first proper driveway on the left and as it sweeps round to the house, go right through 2, maybe 3 gates quite close together, you then pick up tractor tracks going left down to another gate, Left through this and kinda cut across the field, you'll end up in a soggy sunken track with a wall running alongside on the left, follow this to the gate, straight ahead down a nice bit and when you get to the bridge on your left (3 Shires) keep straight ahead again, follow the climb to the top (Cut Thorn) , go right to the A54 and right again, look out for Cumberland Clough on your left.
The field will be a bit soggy but better to descend than climb it IMO
HTH
Carlos
Sounds good thank. I've sent you a map and wondering if you could highlight which section is the descent in question please?
No worries, I'll have a look later.
Which descent do you want high lighting??
The quarries into 3 Shires
Field into 3 Shire
Carlos
