Nasty chain deposit...
[Closed] Nasty chain deposits - any ideas.
[#11762558]
Hiya,
My road bike chains have these nasty deposits on it. Not sure what they are / if I can remove.
The following received a shite spirit bath, wash and scrub, wire wool and then degreaser treatment. But as you can still see, lots on it.
dirty chain
What am I looking at, corrosion? Diesel particulates?
Cheers, Alex
Posted : 19/02/2021 5:12 pm
Shite spirit?
Buy some better quality stuff then.
Posted : 19/02/2021 5:16 pm
The body is willing but the spirit is weak?
I did give it a mic off degreaser too...
Posted : 19/02/2021 5:18 pm
Pic not showing for me?
Posted : 19/02/2021 5:26 pm
No picture for me either....link's bust.
It's probably a combination of road grime & whatever lube you're using. In days gone by I was using 3 in 1 on the recumbent chain. It ended up covering the transmission in what looked like coal. Took a lot of shifting with a wire brush & neat degreaser.
Posted : 19/02/2021 5:46 pm
I'll get in first: squirt lube.
Posted : 19/02/2021 5:49 pm
Using muck-off chain lube too? Its the worst thing ever if you don't thoroughly degrease and reapply VERY regularly - turns into blobs of tar.
Much better alternatives available.
Posted : 19/02/2021 5:51 pm
 jedi
Muc off wet lube does that to my mtb
Posted : 19/02/2021 5:52 pm
Hmmn, annoying about the image.
I'm using ProGold Xtreme on the road bike. Had loads left over from when you couldn't get Rock'n'Roll...
Agree, mic off lubes are poor show IME.
Posted : 19/02/2021 5:57 pm
This might work....
https://photos.app.goo.gl/z1Hy5WPi4gHs6W1T6
Posted : 19/02/2021 5:58 pm
Nope
Posted : 19/02/2021 5:59 pm
*sings the putoline song again*
Posted : 19/02/2021 6:06 pm
Road grime mixed with chain lube. Turns to tar-like deposits. Totally normal.
Posted : 19/02/2021 6:10 pm
* joins in the chorus for the Putoline song..
Posted : 19/02/2021 6:14 pm
Try brake cleaner. Not all degreasers are created equal....
Posted : 19/02/2021 10:52 pm
@ajt123
This site converts the Google Photos "copy link" into a format you can use on here with the IMG tags.👍
https://www.labnol.org/embed/google/photos/
Posted : 19/02/2021 10:56 pm
Bum. This is worse than the chain.
Posted : 19/02/2021 11:40 pm
*sings close harmony baritone part of the putoline song*
Posted : 20/02/2021 12:10 am
@ajt123
On my android.
Click share symbol on pic you want, click "create link". That copies it.
Then paste that into that site I link to.
Let it work then MAKE SURE YOU COPY THE WHOLE LINK IT GENERATES,PART IS HIDDEN! You need to "select all" in the"direct image link" box, then "copy".
Then just use the IMG tags in this site, then job done.
Posted : 20/02/2021 12:18 am
Whatever Poop is using - that’s the stuff you want 😀
Posted : 20/02/2021 10:49 am
