Narrow/wide again -...
[Closed] Narrow/wide again - any difference between the brands?
[#5898348]
The RaceFace N/W chainrings seem to have become the default option but I was wondering if there is much difference between the brands? Works Components are a bit cheaper and UK made, looks are subjective but is there much if any difference in terms of retention performance and/or longevity? I'm guessing they haven't been around long enough for many people to have tried more than one?
Posted : 28/01/2014 10:02 am
Ive yet to see a bad review of any of the narrow/wide. I went with a Works Component one as it's cheaper, and UK made - which is appealling.
The anodising will come off in a couple of rides from the teeth.
a 32t Works + a SRAM clutch + OneUp 42t = perfection.
Posted : 28/01/2014 12:23 pm
Just fitted a raceface to my trance, the reason I chose it was because the majority of reviews are for that type, and they all say that it simply works.
Posted : 28/01/2014 12:28 pm
Raceface one here.
Simply works.
Posted : 28/01/2014 1:48 pm
I went raceface because i needed a 30t
Posted : 28/01/2014 1:51 pm
Cheers fellas. Be interested to see if the new Hope one is competitive on price.
rickon - sounds like you've got your OneUp sprocket installed and tested and that you're pleased with it? How are you finding the mid cassette jump without the 17T?
Posted : 28/01/2014 2:02 pm
 Leku
Works Components here and works well.
Posted : 28/01/2014 2:04 pm
+1 Works works
Posted : 28/01/2014 2:10 pm
 st
Another Works vote here.
I suspect that for the majority of the STW flounce brigade we're a way off people putting sufficient miles on these type of rings to determine whether they A. wear excessively quickly and B whether this wear affects their chain retention performance.
Posted : 28/01/2014 2:14 pm
