Has anyone stayed near Nant yr Arian?
Looking for some bunk house or cabin stile accommodation for 5 in November but struggling to find anywhere nearby or slightly North.
Used Dolgan Uchaf at Dolgellau for the bunkhouse quite a few times. Couple of years since I was last there though. Was nice.
It does seem to be a little lacking in accommodation. There is plenty further north around Machynlleth which is quite a nice area to stay in. Its a bit of drive to NyA but not that far and there is some pretty good riding around there and you can link up with the NyA trails via the mach trails if you fancy a bigger ride
If you search for all accomodation under 'Pont Ryhd Y Groes' on tripadvisor it comes up with some options for cottages. It's a nice little village and only 10 miles from Nant. If not then there is probably accomadation in Devil's Bridge and surrounds which is even closer. Otherwise it is a bit sparse for cabins/bunkhouses
Thanks guys. Devils Bridge was the original plan but it's shut in November, as are a lot of them. Will probably have to go up to Dolgellau I think.
Aberystwyth is way closer and won't be shut!
