Mytracks
[Closed] Mytracks
[#1972284]
I used 'mytracks' on my generic android based phone for the first time this evening.
Seemed to work really well. My short loop was actually a touch longer than I thought.
What I dont get is why the 'pace' is measured in mins/mile. Very strange unit, especially when the others are regular.
Is there a way to change it?
Also any other tips for using it are welcome.
cheers
Posted : 08/09/2010 8:51 pm
Can't help with changing the units, but minutes per mile (or mins per km) is how runners measure their pace, never in mph. Makes sense if you know your pace is 8 mins per mile and you're off for a 5 mile run.
Posted : 08/09/2010 10:46 pm
Ah yes never thought of it like that. I like mytracks infact I like a lot of googles apps.
Posted : 08/09/2010 10:53 pm
I tended to find it only recorded my start and finish point but I think that's more to do with the quality of the gps on my phone than the application
Posted : 08/09/2010 11:03 pm
I use My Tracks loads - and the gps seems to work really well, even in dense tree cover.
I tried Cardio Trainer once, but even on a loop of Rutland water which is largely open there were several locations where there was no route recorded due to the gps dropping out. So, I went back to My Tracks.
If you aren't bothered about seeing the map while you are riding, but use it more for recording distance/speed etc and then reviewing where you've been then it's worth sticking the phone in airplane mode before starting My Tracks....it does wonders for battery life!
Posted : 08/09/2010 11:13 pm
thanks guys.
I figured out the speed thing. Untick 'display pace' in settings.
@stumpy - do you not need the connection to get the map up or does it insert the map when you hook back up?
Would be good to save battery as a 45 min ride used nearly 20% 🙁
Posted : 09/09/2010 7:41 am
You can save battery life significantly by reducing the frequency of GPS readings: Settings -> Recording -> Min time between points. I set mine to 5 seconds and in combination with turning off WiFi etc it will carry on indefinitely (assuming nothing else is chewing up the power at the same time). The track is a bit less accurate but I find it perfectly adequate for what I want.
I had forgotten how much difference it makes until yesterday. I was using a different app, with a much higher update frequency, to track my progress round the red at Dalby and the phone died completely about a mile from the end. Similarly long rides have not been a problem with MyTracks on a slower update.
Posted : 09/09/2010 8:24 am
Yes, deffo stick it in Airplane mode. My Tracks eats the battery on my Hero for fun.
Posted : 09/09/2010 8:26 am
If you stick the phone in airplane mode, you won't get the maps but as soon as you reconnect to the network it will download the map and update - so you don't end up with just a permanent red line.
I used it last week on a 27 mile route (about 2hrs 40 mins) in ariplane mode & from fully charged it only lost 1mm of green from the battery.
I haven't changed my settings related to how often it takes a reading; it's set to highest. I might try changing this adn seeing what happens.
Posted : 09/09/2010 8:52 am
