Little lockdown project. From this;
To this;
Total cost was £13 plus an old innertube and took about 30 mins.
The extinguisher is tested to about 370psi and pressurised with powder to around 270psi (if memory serves correctly). So tubeless at 180psi or below shouldn't be a problem IMO.
Extinguisher here;
https://www.screwfix.com/p/firechief-dry-powder-vehicle-fire-extinguisher-600g/91740?_requestid=726409
Works better than my tubeless pump to be honest. Mainly as it stores more air.
The extinguisher is tested to about 370psi and pressurised with powder to around 270psi (if memory serves correctly). So tubeless at 180psi or below shouldn’t be a problem IMO.
Except you've just drilled a randomly sized hole in a random place on the pressure vessel so those ratings now count for sod all. It's probably fine but I wouldn't rely on those figures for anything now.
I have a big (5l?) CO2 bottle, I used the test port to fit a schraeder valve for filling and converted the horn connection to accept a quick release schraeder head. No drilling required, just a lot of converter pieces!
Why drill it? Pull the handle or put a band around it and you can fill it via the outlet. Just needs a T and a isolate valve. But yes way better than a pop bottle.
No need to buy a new extinguisher. Plenty of used ones out there if you look around. There's always a big pile at the dump if you can sneak one out.
As well as the exploding fire extinguisher in the dustcart this has brought back memories of the compressed air launcher we had at the MOD. Basically a huge tank pressurised to some ridiculous level with a steel diaphragm with a small explosive charge in the middle of it. Blow that and the air launched what ever item we were testing down the test track at incredible speed. I hated being in the control room for that, I think everyone did. Watching all these dials and pipework while the whole thing charged up making horrible noises. Always felt like being in Das Boot, sinking to the bottom just waiting for imminent death! 😬
Not as pretty as @bigblackshed Frankenflater but does the job:
[url= https://i.ibb.co/D93ks4H/A792-C59-B-E86-F-4706-B71-D-6-D107-A7233-C6.jp g" target="_blank">https://i.ibb.co/D93ks4H/A792-C59-B-E86-F-4706-B71-D-6-D107-A7233-C6.jp g"/> [/img][/url]
[url= https://i.ibb.co/FmNbc4c/2-D3-E31-CA-C75-E-4630-A863-4-A4-FEE6-D92-B9.jp g" target="_blank">https://i.ibb.co/FmNbc4c/2-D3-E31-CA-C75-E-4630-A863-4-A4-FEE6-D92-B9.jp g"/> [/img][/url]
