MTB levers with roa...
[Closed] MTB levers with road brakes?
[#693211]
I'm building up a touring/hacking bike for the missus: dinky road frame, 700c wheels, MTB mechs/shifters, straight bars, triple chainset, etc.
I've got most of the bits in the spares box, but was wondering - can you use MTB levers with road (caliper) brakes, or is the pull/throw going to be all wrong? Obviously I have to use road brakes due to the frame, but what levers to use on straight bars?
Cheers, Tom.
Ps - if anyone's got any 700c, 1 1/8" aheadset forks for sale I'd be interested.
Posted : 08/07/2009 1:14 pm
std canti ones yes, v-brake ones will have less leverage and might be hard work/no modulation.
I'd be surprised if road calipers fitted on 1 1/8 AH forks...if that's relevant.
Posted : 08/07/2009 1:17 pm
Dunno about MTB levers, but there are some specific MTB-style levers for road brakes. Shimano M440 or something. Can't remember now.... But they do go cheap on Ebay, let me see if I can find some............
You need levers that are designed for old-style canti brakes (not v brakes). Some Avid levers have adjustable mechanical advantage and will work with either brake type when set right.
Posted : 08/07/2009 1:21 pm
As above, you need the flat bar brake levers (not mtb) that are designed to be used on hybrids to get the right cable pull.
Posted : 08/07/2009 1:23 pm
Unless they're designed for hybrids with v brakes! Which most hybrids are.
Simple answer is - don't ride a road bike with flat bars!
Posted : 08/07/2009 1:26 pm
Can't find any on Ebay, but these are the ones you need
http://www.chainreactioncycles.com/Models.aspx?ModelID=34695
Posted : 08/07/2009 1:28 pm
i've got an old xt v-brake lever running fine with a road canti brake
Posted : 08/07/2009 1:30 pm
You do get 1 1/8 road forks don't you? The frame is a Specialized Sequoia, which is designed for a 1 1/8" headset.
Cheers for the advice, I might have some older Avid levers somewhere, I'll dig em out to see if they're adjustable.
Actually thinking about it didn't some older shimano v-brake levers have a plastic bit you could move to change the leverage? Or did I dream that up!
Posted : 08/07/2009 1:31 pm
I think you could be right ajantom. I know the current ST-EF50 combined brake and shifter units have that capability so it is certainly feasible.
Posted : 08/07/2009 1:40 pm
as said, cantilever levers will work with road calipers. Keep an eye out for SS7 levers as they are comfy and well made.
V brake levers pull too much cable for DPs and lead to a firm lever and not a lot of power.
Avid SD levers on their 'softest' setting just about work, but are still quite firm.
Posted : 08/07/2009 2:25 pm
Yes - sorry I assumed you might be trying to bodge mtb forks on. I'd still check the drop is right for the brakes on whatever fork you get.
Posted : 08/07/2009 2:44 pm
