MTB chainset on a &...
[Closed] MTB chainset on a 'Cross Bike ?
[#1792496]
I've got my brain in a twist over this one ...
I want to use my SLX chainset on a 'Cross Bike (68mm shell / 130mm dropouts)
Should I use an MTB BB or a Road BB? Will I need to source extra BB spacers to use a road BB with an MTB chainset (longer axle?)
And what about the chainline? Won't somebody please think of the chainline!
Anyone done something similar?
cheers
Posted : 12/07/2010 5:22 pm
Use a mtb BB, chainring clearance on granny may be an issue.
Posted : 12/07/2010 5:23 pm
MTB BB as the Road BB is for a smaller Diameter axle
Posted : 12/07/2010 5:24 pm
cheers chaps.. I tried using a road BB on a MTB chainset a while back and it didn't work - only I can't remember why!
Smaller axle is it? Hmm, MTB is 24mm? What's the road axle dia.?
Only have single ring so granny isn't a problem.
Posted : 12/07/2010 5:29 pm
I think the axle diameter is the same, it's the axle length which is shorter on road chainsets.
Posted : 12/07/2010 5:35 pm
I use a trekking xt (26/36/48) on my tourer, the only issue is getting the front mech to work properly with the smaller chainrings.
Posted : 12/07/2010 5:57 pm
I used an slx chainset on my major jake without any problems, It did feel wider than the FSA gossamer cx original that was on but i put that down to there being more angle on the slx arms than the FSA CX ones but could be wrong.
Can't comment on the gears as i ran it 1x9. I did run a pauls chain keeper which worked fine.
Posted : 12/07/2010 7:51 pm
