MTB Bullhorn/ Narro...
[Closed] MTB Bullhorn/ Narrow Flat Bar/ Bar Ends Etc.
[#10542127]
Looking for possible options to allow adoption of a slightly more aerodynamic/ narrower/ more pedalling efficient position on an MTB. Doesn't have to be gnar capable beyond a foot high drop off. Any ideas excluding drop bars?
Posted : 19/03/2019 11:23 pm
narrow flat bars, long stem and bar ends? Or put some aero bars on? ~why?
Posted : 19/03/2019 11:48 pm
I would kill myself with aero bars.
I suppose the question is does anyone make bullhorn bars that take MTB controls?
Having said that pics of setups of any kind would be nice.
Posted : 20/03/2019 12:12 am
The mudplugger I built up for winter has a narrow(ish) flat bar and bar ends. Both Brand X, which are well priced and as good as anything else really, apart from weight i guess.
[url= https://i.postimg.cc/9MrLB2Gd/0_IMG_20190308_172322.jp g" target="_blank">https://i.postimg.cc/9MrLB2Gd/0_IMG_20190308_172322.jp g"/> [/img][/url]
Posted : 20/03/2019 6:12 am
You could get brake levers and grips onto a bullhorn but bullhorns tend to be 40-44 cm wide so are narrow for off road. I use them on my fixed gear bike on gravel and easy singeletrack but the more technical sections are not exactly fun and more a case of just getting through them.
I would go with flat bar cut down to suitable width (which I guess will not be as narrow as 44cm) with bar ends and likely to be around 50cm
Posted : 20/03/2019 7:55 am
the narrowest you can practically go to is about 45cm. Any less and you can't squeeze the levers/shifters/cables on.
Posted : 20/03/2019 8:19 am
On my “gravel” bike (old 26” mtb with bigger wheels and rigid forks), I’m running bar ends inboard of the brakelevers on wideish flat bars. Gives me a position roughly analogous to being on the hoods on drop bars. Looks a bit weird but works very nicely for road/cruisy off-road bits, and still gives me a proper mtb descending position.
Posted : 20/03/2019 9:06 am
Jones bars with a Gnarwhal, or whatever it’s called (pointy thing out the front)?
Posted : 20/03/2019 7:49 pm
