MTB BB with Road Cr...
[Closed] MTB BB with Road Cranks - will it work?
[#5878022]
Can i run shimano road cranks with my spare shimano typeChris king BB?
Looks like the cups are 1mm wider on the road ones, so is it just a case of using the external spacers as needed?
Will i cause any lasting damage?
Posted : 21/01/2014 8:24 pm
Chainstay clearance, chain line and whether your front mechs will be the concerns.
Posted : 21/01/2014 8:26 pm
Clearances should be fine as it's a cross frame with 135mm rear spacing. I don't have the cranks to try, only the BB at the moment, hence asking.
Posted : 21/01/2014 10:12 pm
So if its a 68-73mm BB shell then the cups are 1mm wider on one than the other (road bike I believe) and the road bike should have no spacers. Be wary here as I didn't realise and kep the original MTB setup only to find I'd cut the chain too short when I realised my mistake! You need to check what width of BB shell you have and what the road cranks require.
Posted : 22/01/2014 1:26 am
If needed, Hope make the required 1mm spacers (BBSP105)to correct the width difference. Also worth noting that they make a narrower central sleeve for their road BB, as the standard MTB one is too wide, may not be a problem with King but worth checking before you damage anything.
Posted : 22/01/2014 8:32 am
Thanks of the hope spacer tip. Not tried it out yet, but will take all onboard.
Anyone out there actually tried this yet though?
Posted : 22/01/2014 11:14 pm
