MTB and Road bike s...
[Closed] MTB and Road bike sizing how to compare?
[#6760470]
Ive sold my Boardman hybrid as I fancy a nice road bike to commute on instead.
There is a nice Planet x carbon road bike in the classifieds in Large but Im not sure if it will be to small or not as the top tube is around 4 cm shorter than my full susser.
Looking at the planet x website it says large is the right size for me but the top tub length thing is worrying me!
should I be comparing bike sizes like that or is there another way.
Buying seconhand is going to get me a good deal but without the chance to test it.
Posted : 07/01/2015 4:14 pm
not discounting the fact that 'top tube' measurement can mean different things to different manufacturers, don't forget that on Flat bar bike (MTB/hybrid)
TT + stem length - bar sweep back
Is where your hands end up, on a road bike its more like
TT + stem length + bar reach + hood length
eg:
take MTB 60mm stem (gah, mixed units!) so reach is TT + 2.5in
vs
on road bike it's 100mm stem (shortish on large), making TT + 4in but then you could have 70-100mm of bar reach putting another 3-4 inches on, before you even add the reach of the hoods.
but as always, try before you buy!
*ignoring bar width for now although that obviously does affect final body position on both types.
Posted : 07/01/2015 4:39 pm
You can't really compare because they're completely different bikes, but having said that...
Road bikes generally have longer stems than MTB, which would make up the difference in TT length: My MTB has an ETT of 615mm, but a 35mm stem, while my road bike is 550mm with a 110mm stem, so works out slightly longer.
Edit: Beaten!
Posted : 07/01/2015 4:41 pm
As a very rough guess (they're completely different beasts, obviously), that sounds about right - I ride mtbs with about 590- 610mm top tubes and short 50mm-ish stems, and road bikes between 545-565mm ETTs, 100-120mm stems, and short reach bars (80mm). Remember you've got a long stem (90mm+ normally) and the reach of the drops (75mm+) to add to the road bike figure, plus saddle to bar drop - it'll most likely feel plenty long enough, but you've really got to ride it to find out (and know what it should feel like!)
edt: beaten, twice 😥
Posted : 07/01/2015 4:43 pm
You don't. You don't even compare road bikes sizes as the geometry etc will be different.
Why not just look at the website and see what's recommended+?
Posted : 07/01/2015 10:18 pm
