Mt5 equivalents?
Mt5 equivalents?
[#12880342]
What 4 pots similar in price and performance are you lot using - comparable with mt5s
Posted : 06/07/2023 3:11 pm
Is there a reason for not using mt5?
Posted : 06/07/2023 3:16 pm
I've currently got them on 2/3 bikes and looking at the 3rd. anything else to consider for it
Posted : 06/07/2023 3:19 pm
At a similar price I would imagine something like Sram guide re. Over that price it would be codes or Hayes dominion a4 I imagine.
I bought my magura mt5 for £75 each and most equivalents tend to be higher.
I bought guide re cheap on crc but I don't really think they are on same level.
Posted : 06/07/2023 3:22 pm
 Yak
If you have them on 2 out of 3, then stick with them. No point making life hard with different bleed kits, different pads etc. The only thing to consider is changing the lever for a different feel if you want to.
Posted : 06/07/2023 3:24 pm
matt_outandabout, kelvin, bikesandboots and 1 people reacted
Just fitted some, reasonably straightforward, cutting re-assembly, all easy enough.  bleeding is a bit of PITA as no bleeding edge, so endless 2 syringe back and forth, weirdly getting pads in and out is a struggle (might be just me).  In use perfectly fine. wouldn't wholly recommend them over anything else at the same price.
Posted : 06/07/2023 3:29 pm
CRC had Code R on offer for just below £100 an end recently. Might be worth seeing if they still have them.
But if you have all the stuff for bleeding MT5 and you like them then why not just get the same again?
Posted : 06/07/2023 3:39 pm
Shimano Deore 6120 are excellent brakes, and can be had for around £50-£60 an end.
I paid closer to £100 an end during the Covid boom and don't feel short-changed. They basically feel the same as my trusty Zees.
Posted : 06/07/2023 4:06 pm
Got bleed kits for All brakes
Posted : 06/07/2023 4:13 pm
Magura MTB-Bremse MT5 4-Kolben, Schwarz https://amzn.eu/d/bKYDGUI
I'd just buy more mt5 from amazon
Find some 2nd hand Zee or Saints
Posted : 06/07/2023 6:12 pm
I prefer the MT5 to saint and sram, in terms of braking force and feel, but the levers are shit.
I’d be looking at the Hayes.
Posted : 06/07/2023 7:42 pm
If you're going for SRAM I think you need at least RS to get the swinglink to get a decent lever feel.
I run Code calipers with Guide RSC  levers on one bike and Guide Ultimate levers on the other and find them excellent.
Posted : 06/07/2023 8:46 pm
deffo not sram - never liked the feel - that's just a  personal thing though
Posted : 06/07/2023 8:47 pm
Shigura! If you like MT5s but not the levers
Posted : 07/07/2023 12:36 am
jeffl reacted
MT5s with Oak Components levers...
Posted : 07/07/2023 2:45 am
They now do a mt5 pro set ,4 pot mt5 caliper with the much nicer 1 finger lever .
Got mine for just over £200 from winstanleys
Highly recommended
Posted : 07/07/2023 8:05 am
malv173 reacted
And comes with rotors 203/180 currently £207
Posted : 07/07/2023 8:08 am
Mt5 (with a 1 finger lever) is a great brake, just stick with them. Super easy to do a quick lever end only bleed too.
If only r2 would still deliver sub €160
https://r2-bike.com/MAGURA-MT5-Set-Disc-Brake
Posted : 07/07/2023 11:10 am
