Moving Seat post - ...
[Closed] Moving Seat post - Orange 5
[#810697]
Hi all, running a Thompson post with the orange and its slipping about an inch when climbing.
Im only guessing its the right size... it came with the bike!
I've also put a hope clamp on as its a nicer clamp and a little more comfortable in the hand.
Any thoughts on what to do to stop it?
Posted : 24/08/2009 8:05 pm
Orange 5 + Thomson post here with no probs.
Clean the post, add a little grease & clamp up tight
Posted : 24/08/2009 8:09 pm
Take the post out, give the seat tube a good clean along with the post and apply some waterproof grease to the post.
Ensure the clamp is done up nice and tight too
Posted : 24/08/2009 8:10 pm
eat less pies and do more exercise 😉
doubt if that is of any help
Hmmm.... its brand new. Cant see its all that dirty tho.
Ill have a look at cleaning it up tho.
Carbon grease going to be a bit grippier?
Posted : 24/08/2009 8:14 pm
Hmmm mine slips too........don't have a hope clamp though was thinking of changint it! I don't want to have to do it up toooo tight as I do up and down it quite a lot!!!
Posted : 24/08/2009 8:17 pm
Hope clamp has a nice brass bushing, I thought it would also be better on the leverage front. Still not tight enough tho!
Posted : 24/08/2009 8:24 pm
Made for Pace
RC005 Carbon Composite Shield
A small tub of blue goo to you, but a life changing synthetic suspension of friction increasing polymer globes as far as your sinking seatpost is concerned. A thin smear is enough to reduce clamping torque on carbon or alloy seatposts by up to 30%, minimising the risk of crush or cracking damage and keeping your seat height right for ride after ride.
Specification 80g
100% fully synthetic. 30% reduction in
clamping torque
Posted : 24/08/2009 8:27 pm
Well done Andy.... I've got the finishline version ill give it a try when i wash it in a mo!
Posted : 24/08/2009 8:33 pm
mine slipped with the oem clamp - got a nice salsa flip off and crank it up nice and tight and now sorted!
Posted : 24/08/2009 9:14 pm
My original clamp cracked but the hope one I replaced it with seems solid enough, make sure the clamp quick release is well lubed to help squeeze clamp tight - made a hell of a difference to ease of use on the clamp!
Posted : 24/08/2009 9:22 pm
You do not need to lube the Hope clamps or skewers, the brass bush needs no lube, if you lube them they have a greater chance of coming undone.
Posted : 24/08/2009 9:30 pm
Brass is supposed self lubricate, but it doesnt seem to be that smooth when mega tight. leads me to believe its not the clamping pressure that is the issue.
Posted : 24/08/2009 9:38 pm
 Del
that is correct, but not necessarily true.
do you you have a bit of tyre on the down tube too....?
Posted : 24/08/2009 10:22 pm
Get in touch with Orange and talk to the Technical department very helpful.
Posted : 25/08/2009 2:16 am
Del - why would he want a piece of tyre on the downtube, that just looks rubbish... 😉
Posted : 25/08/2009 9:41 am
try a diffrent qr .a mate had the same problem with hope qr and thomson post on a 5 changed the qr now its sorted. they look nice the hope 1s but i have heard loads of people saying how there seat keeps droping. i havent had a problem with mine but i guess the lighter you are the better
Posted : 25/08/2009 10:37 am
 hora
I use an old Thomson post, original OEM Orange QR and havent had any probs- as above clean and regrease?
Posted : 25/08/2009 10:43 am
