Mountain bike Drago...
[Closed] Mountain bike Dragons Den
[#4809631]
In the spirit of the innovation thread...
What would you take into the dragons den relating to mountain biking?
and who would be on the panel?
Posted : 29/01/2013 11:42 am
30.5" wheels.
Rob Roskopp, Steve Peat, Peter Jones, Beyonce
Posted : 29/01/2013 11:55 am
Electrically controlled dropper seatpost. It makes more sense to get rid of the cable from a dropper post than gears because so many of them are retrofits, and also for some of the designs you have to deal with a changing distance that the cable has to cover
Posted : 29/01/2013 12:18 pm
a gun.
to kill the dragons and then steal their cash piles - get it.
Posted : 29/01/2013 12:19 pm
Mind controlled, fully enclosed infinitely variable gears.
Posted : 29/01/2013 12:20 pm
beyonce? perv. lol
Posted : 29/01/2013 12:21 pm
31" wheel mountain bikes.
Posted : 29/01/2013 12:22 pm
Self cleaning MTB
Posted : 29/01/2013 12:23 pm
29.5" wheels
Posted : 29/01/2013 12:26 pm
A terrain-adaptive tyre. That would end all the bloody 'what tyre for...' threads 😉
I posted this a while ago.
Call me stupid but...
If the idea of tubeless is to remove the weight / feel of the inner tube and prevent / minimise punctures but the downside is the faff, why not, have a very thin latex tube, with a profile similar to a tyre and pre filled with some sealant (think condom like tube complete with spaff).
The pre filled Johnny tube (as it will now be called) would have a regular valve and set up would be very simple. Inflating would fill and pressurise the void in the tyre / rim without the need for all the faff and paraphernalia of tubeless and without (i assume) the weight and feel of a standard tube. Punctures if they rip both tyre and tube could still be sealed by the spaff.
(steps back and awaits ridicule)
Posted : 29/01/2013 12:28 pm
Nice Try but I'm not giving away my genius ideas on the interweb to you lot!
Posted : 29/01/2013 12:30 pm
Wooden tyres shod with a iron hoop - no more punctures and would appeal to the retro rider.
belt drive, bottom bracket hub geared bike
Posted : 29/01/2013 12:32 pm
stevied - Member
http://dirt.mpora.com/featured/fresh-produce-adaptrac.html
Posted : 29/01/2013 12:40 pm
uwe-r, you are stupid 🙂
You have invented a tyre and inner tube with slime in the inner tube.
I remember filling my latex lightweigh tubes with slime from my offroad motorcycle back in the late 80's.
Still did end up with a puncuture eventually and found you couldnt patch the tube.
Posted : 29/01/2013 12:43 pm
36" wheels
Posted : 29/01/2013 12:56 pm
i run slime in a regular inner tube. haven't got round to tubelessing the rim, 'ghetto' or otherwise.
haven't had a punture (or one that didn't fix itself)in 2 or 3 years : )
Posted : 29/01/2013 1:00 pm
Kylie, Jess Ennis, Madonna, Beyonce and a pot of vaseline
A properly designed tool to push back brake pistons. No more screwdriver/tyrelever lash ups.
Posted : 29/01/2013 1:01 pm
You sick sick man
Posted : 29/01/2013 1:04 pm
Action Romper - all in one man sized gortex jump suit that connected to waterproof boots to keep you warm and dry in the winter.
Helium filled frames and tyres for even radder 'air'. Optional bite valve for post-ride comedy voices.
Danny Mac, Grayson Perry, Rob Warner, Niki Gudex. 😀
My own:
shoes with different tread for different conditions, swappable, spikey for deep mud like we have mostly now and less agressive for the summer.
cleats that can easily be removed, with internal locking mechanism that doesnt need a vice / copious amounts of oil / long leverage just to shift the rusty allen nut, grrrrrr.
Posted : 29/01/2013 1:05 pm
jekkyl - Member
shermer75 - Member
29.5" wheels
jekkyl - Member
36" wheels
More wheel size suggestions please! Don't be put off by that fact that you were beaten to the punch by kayak23 in post 2 - the 'joke' is so [i]hilarious[/i] that it can bear umpteen variations on the theme before it gets old...
Posted : 29/01/2013 1:21 pm
an airbag body suit for those unexpected moments AKA crashes
nicole scherzinger / john castellano / carla from corrie / jon whyte
Posted : 29/01/2013 1:23 pm
Bike sails
The late Don Whillans, Harry Hill, John Lydon, Shaun Palmer
Posted : 29/01/2013 1:36 pm
I've said this before but apparently nobody picked up on the sheer genius of it.
5:10 pedals...
The pedal itself is covered with stealth rubber in a slab (No more pedals full of mud) and your shoes have the pedal pins in them.
No more pedal rash!
I know....utter genius.
8)
5:10 pedals, now that does seem like a good idea 🙂
So, brainiacs, why won't it work?
APF
Posted : 29/01/2013 1:40 pm
To keep with the typical calibre of a DD contestant - A mountain bike with a motor. It'd be amazing, you could go uphill as fast as down! It's called a motor-mountain-bike! Then when they tell me these already exist I'd get all sweaty and stroppy and say they're not the same, then make up a desperate innovation on the spot like having 23 wheels and a microwave.
I guess your mum might go a bit mental if you got your pinned shoes near her parquet...
Posted : 29/01/2013 1:44 pm
Frame/component coating made from 'graphene'. 200 times stronger than steel,as light and thin as silicone and doesn't degrade and is impervious to scratches. Could be extremely cheap too.
A 0.1mm covering would make your frame/components 'literally' bombproof... but also highly conductive if hit by lightning!
Manchester Uni just got a £32m grant to develop the stuff further.
I win!
Posted : 29/01/2013 1:49 pm
37" wheels.
Posted : 29/01/2013 2:27 pm
 LoCo
Tapered fork axle one side 20mm (caliper side) other 15mm, 😈
Single sided rigid forks, single sided hardtail frames,
Carbotianium frames
Posted : 29/01/2013 2:30 pm
25" wheels
Posted : 29/01/2013 2:52 pm
don't be silly 25" wheels would never work.
I'm ooot.
Posted : 29/01/2013 3:03 pm
jekkyl - Member
shermer75 - Member
29.5" wheels
jekkyl - Member
36" wheels
More wheel size suggestions please! Don't be put off by that fact that you were beaten to the punch by kayak23 in post 2 - the 'joke' is so hilarious that it can bear umpteen variations on the theme before it gets old...
It's the repetition that makes it funny. You, on the other hand, come across like a grumpy tit.
http://mrsimontaylor.wordpress.com/2010/12/03/the-psychology-of-comedy-rule-of-threes/
Posted : 29/01/2013 3:09 pm
Unobtanium frame with kryptonite dropouts
Posted : 29/01/2013 3:12 pm
.....and 1" wheels
Posted : 29/01/2013 3:14 pm
maybe we could have incremental clip on wheel size increasing rings!
with the appropriate dropout extender widgits:-)
Posted : 29/01/2013 3:17 pm
If I'm grumpy, it's because of the poor quality of posts on this thread. Buck your ideas up, Mr.
660mm wheels
Posted : 29/01/2013 3:34 pm
1 3/8" headtube standard
Posted : 29/01/2013 4:00 pm
i can see trek's marketing. . . i mean R&D department fapping all over this thread and thinking of anacronyms for all these silly idea's.
Posted : 29/01/2013 4:22 pm
rickmeister - Member
POSTED 3 HOURS AGO # REPORT-POST
Piston and Brake alignment tool
Posted : 29/01/2013 4:27 pm
Or the Park PP-1 Hydraulic Brake Piston Press
Posted : 29/01/2013 4:36 pm
 Gunz
I didn't know who Niki Gudex was so have just Googled her. Jesus wept, I'm going to have to update my pink chit.
Posted : 29/01/2013 5:13 pm
