Most basic Garmin s...
[Closed] Most basic Garmin suitable for cycling?
[#6273287]
Sadly my old Forerunner 305 has died.
All I want from the replacement is:
1. Ability to upload GPS to Garmin Connect/Strava
2. See from the screen what time it is and how far I've been
Looking for something second-hand and cheap. Not sure if the really basic watches will do this - or if the battery lasts long enough (8 hours would be good) - any experience/advice please?
Posted : 16/06/2014 10:57 am
An Etrex H will do this and you can get them for not a lot on ebay.
Posted : 16/06/2014 10:59 am
Aside from the battery requirement you can do this with your smart phone. FYI smartphone will last longer if you turn off uploads as you ride, so just upload track at the end instead of constantly.
Posted : 16/06/2014 11:01 am
There's a whole thread on that. 🙂
You won't get 8 hrs though.
http://singletrackworld.com/forum/topic/home-made-gps-with-mapping-and-tracking
Posted : 16/06/2014 11:03 am
Edge 200, although the time of day is a little obtuse to find om the home screen (and small!). Used will be about £50.
Posted : 16/06/2014 11:09 am
ive got an old foreunner 205, which does all that battery life is very good- 10 hours, however the memory is too small, even with the smart recording option youll struggle to get 8hr in there, hopefully newer ones have more memory
fwiw sportspursuit some on sale at the moment....
Posted : 16/06/2014 11:12 am
As @nemesis says buy something second hand, I have an old Garmin Map handheld (7 years old now, works perfectly), I am sure you could pickup similar second hand for £50-ish
Posted : 16/06/2014 11:19 am
Edge 200?
Posted : 16/06/2014 11:35 am
I notice that some models state they're easy to read in bright sunlight so that's certainly an improvement on my old Etrex.
Do you want to follow a pre-planned route by using mapping software?
Etrex screens are small compared to the Edge models.
I keep dithering about replacing mine as the screen is cracked and struggle to read it as text is feint. Also it's not keen on dense woodland. Trouble is I couldn't bear to pay hundreds of Pounds!
Posted : 16/06/2014 11:37 am
Be careful with the Edge 200. The sampling rate can't be altered and therefore 'automatically' decides when to take a GPS reading. I found that after uploading data to Strava that some segments were missed as it wasn't checking my position frequently enough.
Posted : 16/06/2014 12:16 pm
My Edge 200 has been great. I don't care about HR or other training data, I don't do Strava, does all I need.
But I quite like the look of tbe 800 touring.
Posted : 16/06/2014 12:25 pm
Thanks for all your suggestions. Still unsure which model does exactly what and whether it does it adquately, so I copped out and bought another second-hand Forerunner 305 on Ebay the same as the old one, at least I know what to expect 🙂
Posted : 16/06/2014 7:12 pm
bryton rider 40e on CRC for £75. strava linking may be an issue.
Posted : 16/06/2014 7:26 pm
You'll get way more than eight hours from a smartphone if you hook it to an external battery pack.
For long all day trips I mount my phone on the bars and have a very short lead running to a battery pack in the side pocket of a tri bag. Works very well.
Posted : 16/06/2014 8:34 pm
