Just prtting around with my new forks and have a couple of questions.
How many Tokens are you running, i have 2 spare and i assume 1 fitted (12.5st)
Will the hose guide take a braided Hope hose, looks tight.
Running 1 token, 60psi, 7 clicks of LS compression from - and quite a bit of rebound (7 clicks back from fastest) kitted up I'm not far off you at 13st
I'm not a serial faffer so the above settings don't get changed. I ride all over Wales, The Peak District, The Lake District, Rivington, Hebden Bridge etc... don't do trail centres really
Edit - no idea about the hose
I can confirm that a braided hose will fit - well, it does in mine
2 tokens (I think) and 80psi but I'm a good 14.5 st
Numbers are all irrelevant unless you're comparing the exact same spec forks (travel, wheel size, solo/dual position). The different travel and wheel size Lyriks have different volume air chambers.
I run 95psi, 3 tokens, 4 clicks from fully open compression on 160mm 29er dual position. I weigh about 85-90kg depending on kit/pies.
