More Focus Woes....
[Closed] More Focus Woes....
[#1929176]
bu$$er $hit, w@nk....
A couple of months ago my wifes '06 Focus 2.0 TDCI neede a new clutch and DMF....kerrrr and f..ing ching.
Now it is getting harder to start, at times won't throttle and a couple of times has started and refused to budge from idle. Eventually with a veeeery gentle tickle of the throttle, it'll 'clear itself' and throttles normally.
After a quick Google, main culprit 'could' be ERG valve but also a host of other things.
Any pointers/direct experiences/advice from the STW motoring massive please and what is this likely to cost to resolve?
And I always thought the F.O.R.D acromym was a bit of a joke 🙁
Posted : 25/08/2010 8:01 am
Take it to your garage (doesn't have to be main dealer) and get a diagnostic check done, it should be a better diagnosis than the internet. Egr valves can be cleaned out, although that should would put a fault up. At least that should give you the problem to be solved.
Posted : 25/08/2010 8:11 am
Thanks boobs. It's booked in for a diagnostic, I just wanted some info ahead of time to help sift the bull from the $hit.
Posted : 25/08/2010 8:26 am
